Budget brake upgrade for 2000 Silverado. (05+ front, SUV rear)
Old Aug 13, 2012 | 07:51 PM
  #51
Ferocity02's Avatar
Originally Posted by 99Laydorado
I assume by what youre saying then that you ordered the eradispeed pre 05 rotors?
Bought them from a member. They were 1-piece and I think discontinued. You can get Summit 14" rotors too for cheap.
Old Aug 14, 2012 | 07:47 AM
  #52
99Laydorado's Avatar
Registered User
got ya got ya you was it pre 05 tho or order according to caliper?
Old Oct 23, 2012 | 04:15 AM
  #53
CashDudeHomie's Avatar
Will 05 Tahoe Z71 rear brakes clear a 16 inch wheel?
Old Oct 24, 2012 | 10:09 AM
  #54
Johnmaster's Avatar
MASS seller approved
I have an 04 ss with these "big fancy brakes" and they actually are one of the least desirable parts of the truck. Does anyone know why these trucks don't have a firm brake pedal? We hop in my wife's acura and I nearly throw us through the windshield because I am used to spongebob squishy brakes. I bled my 99 with a vacuum bleeder and they both are way softer than i would want. Is it the abs system? Feels like the pedal is spring loaded when the abs activates in the winter.
Old Oct 24, 2012 | 11:07 AM
  #55
1FastBrick's Avatar
Custm2500's Rude Friend
Have you had a the brakes bleed through the abs module with a scan tool??? It pulses the abs and brings the pedal up and down while you press on the brakes. It usually makes a big difference vs just bleeding them normally.
Old Oct 24, 2012 | 11:16 AM
  #56
Johnmaster's Avatar
I have not, the ss should have never been touched from the factory but my 99 has been changed however has not been bled with a scan tool. Suppose I will just google for the procedure.
Old Oct 24, 2012 | 01:04 PM
  #57
1FastBrick's Avatar
You need a scan tool with the bi directional capabilities like a tech2. Not sure what aftermarket tools have that ability. It's called automated bleed procedure.
Old Oct 24, 2012 | 04:06 PM
  #58
chris99gmc's Avatar
that's interesting.. I might have to give that a shot...
BTW, I did the 14" Baer eradispeed plus 2 rotors on my last truck, and didnt touch the pads or calipers and It was one of the best brake upgrades I've ever done. I could have done w/o the 14" rears(keeping in mind using a stock size spare tire/wheel) to save some money... I think you can get matching rear rotors in the smaller size.
Old Jan 22, 2013 | 10:37 AM
  #59
bluebird71's Avatar
So If I have 16" wheels, I can't run the bigger calipers, not even the rear Tahoe ones?
Old Jan 22, 2013 | 10:40 AM
  #60
iregret's Avatar
Charlie Murphy!
You can run the Tahoe rear dual caliper with a 16" wheel, but the 05+ front caliper and rotor require a 17" wheel at least.
