Broke tranny again, HELP!
Old Dec 19, 2005 | 11:10 AM
gonzo 6.2's Avatar
Originally Posted by Kano
I broke one because it wasnt engaged enough
I would use washers and mic em and sand them down on a flat surface
till there equal
You should see no more than 3/16 between the flexplate and lugs
I checked this distance with a drill bit
Yep,you dont want the converter shimmed tight to the flexplate.Once the trans is bolted to the engine flush,then the converter needs to be scooted forward into the back of the crank and made flush to the converter.that scooting forward amount should be around 1/4" or 3/16 like you said.
Old Dec 19, 2005 | 11:13 AM
Kano's Avatar
sometimes build heights are off
stock
PI
Old Dec 19, 2005 | 11:17 AM
Kano's Avatar
exactly
a couple of more things I found out
was to sand the paint off the pilot
and also check to make sure youre in the 3rd click
like shown above or youll be dropping it back down
Old Dec 19, 2005 | 11:50 AM
gonzo 6.2's Avatar
3rd click is not a good way to gauge it,the best way is like what you have done,lay a straight edge across the front of the bellhousing and measure the distance into the converter mounting pad.YOU MEASURE THE OLD CONVERTER FIRST,before you remove it.then you will know how far the new converter should sit in.
The converter manufactures must want the novice's to ruin there new converters and pumps,they like getting there converters back to repair them.If this wasnt true they could easily ship with the converter a cardboard gauge to ensure the customer fully installed there new converter.
cleaning the pilot paint off is a good idea too.Lube the hub also
Old Dec 19, 2005 | 06:46 PM
99Silver6.0's Avatar
till there equal
Pretty much what I did right there. Miced and used different thickness shims to take up my space. But I spun and spund and spun on the verter till I knew dam sure it was engaged.
Old Dec 19, 2005 | 07:27 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
I did the three click thing to and made sure it was recessed into the bellhousing and not fluch. If it is flush then it is only on the second click and ahsnt engaged the pump dogs yet not to mention it wont go in.
Wolftrk99
Dec 3, 2015 08:12 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
Velocity1
Oct 2, 2015 08:01 AM
Wrecker 426
Sep 30, 2015 09:39 PM
sTNT971
Sep 26, 2015 06:27 AM
