Broke 80e
Old Jan 29, 2009 | 05:28 PM
  #41
charcold-bowtie's Avatar
I was told the OD sprag broke. builder covered parts labor and shipping. Should have it fixed next week.... its on the way back
Old Jan 29, 2009 | 07:15 PM
  #42
BlackGMC's Avatar
Resident Retard
Awesome, did you have him set it up the same way it was before?
Old Jan 29, 2009 | 10:10 PM
  #43
thunder550's Avatar
High on diesel fumes
Cool, glad to hear that he stepped up and took care of you.
Old Jan 29, 2009 | 11:19 PM
  #44
James B.'s Avatar
It's actually a roller-clutch in the overdrive, not technically a sprag. The problem with pre-2001 4L80-E overdrive roller clutches is that the rollers tend to skew minimizing their contact which causes the rollers to wear unevenly. They eventually let go. For the 2001 model year the entire assembly was redesigned with rollers captive in little shoes that keep them square. This assembly is available as a retrofit into all older model 4L80-E transmissions. Unfortunately, it is not inexpensive.
Old Jan 29, 2009 | 11:50 PM
  #45
Ahh, I think thats what he referred to it as...
Thanks for the info, yet again James.
Im back with the same unit, same case. It is still vac modulated. He said too many tuners get too carried away with the shift pressures....
Im hoping this was from a bad rebuild. I mean it lasted two days, not much WOT behind a turbo 4.8L....
Old Jan 30, 2009 | 04:35 PM
  #46
built408's Avatar
I think you have the worst transmission luck then anybody I have ever know.
Old Jan 30, 2009 | 04:40 PM
  #47
BlackGMC's Avatar
Resident Retard
Did you ask him if it came with a filter this time....
lukn4trbl355
Oct 21, 2015 11:19 PM
Velocity1
Oct 2, 2015 08:01 AM
Wrecker 426
Sep 30, 2015 09:39 PM
mitchellmade
Sep 27, 2015 08:27 PM
01silvy
Sep 26, 2015 10:20 PM
