Broke 80e
#25
it was always this way? you did hook up the vacuum mod right?
Well I would start by checking line pressure... there is a 1/8 npt fitting behind the neutral switch, hook a 0-400or 500 psi gauge up and see what you have....
test pressures in park/neutral, in reverse, in drive, and overdrive...
#26
Man, I feel sorry for all the problems you've been having. Hope you get this issue worked out. Did you put a check valve on the vaccum line going to the trans? If they left the filter off, there is no telling what all could be messed up inside. Let me know if you need any help getting it fixed...
