Break in period
Old Sep 12, 2010 | 09:28 PM
mhotrodscooter's Avatar
Default Break in period
Is their a break in period on the Circle D stalls?
Do I change the fluid when I install the new verter r wait for a couple of miles?
Old Sep 12, 2010 | 10:44 PM
brent5631's Avatar
You'll need to top it off at least.
Old Sep 12, 2010 | 10:53 PM
fredkj3's Avatar
you are going to have to continue to check the fluid.... as the converter fills up your level will drop... you also should stay out of the gas and do not brake stall the converter for a couple hundred miles... i know thats what yank tells you to do.... it says you could damage the clutches
Old Sep 12, 2010 | 11:05 PM
budhayes3's Avatar
PT's Slowest Truck
I went 500 miles with my Circle-D multi-disc and FLT Level7 which were done together, it may be less for just the converter though...
Old Sep 12, 2010 | 11:26 PM
FLT's Avatar
FLT
FormerVendor
I thought the CD converters came with some sort of paper work on this but I could be wrong. I would either call Chris direct, shoot him a pm or go here...http://www.circledspecialties.com/askchris.aspx
Old Sep 13, 2010 | 07:59 AM
D_reks{5.3}'s Avatar
When I ordered mine, I talked to Chris and he said make sure it goes through the gears and locks up. Then let er rip... Even tho I didnt because I had to break my trans in to.
Old Sep 13, 2010 | 08:11 AM
Thanks guys, so go ahead & put new fluid & filter!
Old Sep 13, 2010 | 10:24 AM
Circle-D's Avatar
Former Vendor
No real break in on a converter. Install, road test, check fluids, go to track.
Chris
Old Sep 13, 2010 | 10:35 AM
00ChevyScott's Avatar
Wearin' da big hat
Chris
That's what I did
The night I got my truck back from Chase, the roads nearby got some new stripes
Old Sep 13, 2010 | 11:24 AM
06Sierra2's Avatar
yeah i checked fluid, drove around a few miles, checked fluid again, wot
