Brake shake?
Old Oct 22, 2009 | 03:53 PM
mobster38's Avatar
Default Brake shake?
06 ccsb sierra i just put a set of 20s on and the brake shake is out of this world i put new rotors and pads on and it still does it was wondering if the extra weight of the wheels is doing something to the antilock system or any suggestions my rack felt a little loose on the passenger side any suggestions would be appreciated thanks Jay.
Old Oct 22, 2009 | 04:04 PM
00Silv4.8's Avatar
sounds like you need a balance or to pull the brake clips off. 20s shouldnt shake it unless theres a serious problem... loose wheel, warped rotors (which is possible even in a short time), brake clips, etc.
Old Oct 22, 2009 | 04:10 PM
mobster38's Avatar
thanks for reply wheels go down the road perfect at any speed and i just now put the rotors on but i left the clips on every now and then it wont do it getting flustrated thanks
Old Oct 22, 2009 | 04:33 PM
dirt track racer 81's Avatar
take the clips off that hold the rotors on
Old Oct 22, 2009 | 04:38 PM
xlcooplx's Avatar
word, remove the clips.
Old Oct 22, 2009 | 04:42 PM
mobster38's Avatar
it doesnt have clips holding the rotor on it has a torx headed bolt on it
Old Oct 22, 2009 | 04:47 PM
how bout the back. did you take those off too
Old Oct 22, 2009 | 04:56 PM
BadAssChevy327's Avatar
the rear is drums on your truck. take the clips off around the stud.
aftermarket wheels sit completely flush normally so this causes a shake real bad
Old Oct 22, 2009 | 09:52 PM
mobster38's Avatar
I love you guys I would of never dreamed that 2 washers that thin on the back would cause a shake that bad up front thanks a million Jay mobley!!
Old Oct 22, 2009 | 11:50 PM
budhayes3's Avatar
PT's Slowest Truck
Yep, those clips won't allow most aftermarket wheels to sit flush and torque down properly
RustyD
May 23, 2016 07:04 PM
turbo6c3
Oct 5, 2015 06:11 PM
KINGCYCLES
Oct 2, 2015 10:21 AM
Noah Burns
Sep 13, 2015 09:28 AM
Alco
Sep 4, 2015 04:08 PM
