Best tranny for powerful motor?
Old Aug 24, 2006 | 08:29 PM
Jerm83's Avatar
Default Best tranny for powerful motor?
What is the best tranny for my 99 ext cab 5.3 z71? I have a 4L60E in it now. Can the 4L60E be rebuilt to handle 500-600hp? If not, what tranny should i get?
Old Aug 24, 2006 | 08:36 PM
nonnieselman's Avatar
if you plan on abusing the truck pretty good, might as well get a 4L80E.. the 60E is pretty fragile as some say.
Old Aug 24, 2006 | 08:37 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
500+=4l80
Old Aug 24, 2006 | 09:31 PM
thunderwagen's Avatar
80E all the way
Old Aug 25, 2006 | 12:52 AM
Jerm83's Avatar
What trucks are the 4l80 out of, the HD's?
Old Aug 25, 2006 | 01:30 AM
kbracing96's Avatar
Ya, the HD have 80's but it's not a direct swap, it actually pretty involved. Its a longer trans, so you have to modify the crossmenber and both drive shafts, plus there is a wiring harness adapter you need and a few other things. Speed Engineering sell a complete kit with everything you need for the kit http://speed-eng.com/store/product_i...oducts_id=7612
You will also have to have the PCM tuned for it also.
Old Aug 25, 2006 | 02:13 AM
Mr. Sandog's Avatar
6l85e.
Old Aug 28, 2006 | 08:30 PM
rednecknate's Avatar
Default 80
4l80e strong power robbing son of a bitch!!!! just dont get a special made torque convetor like i did.....gm has the adapter for the crank!! mine cost me almost 5k with a low mile used trans..and all the work myself..and the smashed hand from it falling of the jack!!!!!!!!!!! THEY ARE HEAVY!!!
Old Aug 28, 2006 | 09:02 PM
parish8's Avatar
single digit dreamer
$5000 seems prety high to me.
i got a used tranny with extras like dip stick tube, converter cover, tranny mount, flex plate all for $1000. then add ~900 for a good converter(you could go less). $109 for a shift kit, $160 for 2 drive shaft mods(4wd), modified the cross member myself but figure $100 for that, i dont remember how much the harness was, seems like it was $200 with programing but i think that has gone up. i got new lines too and a cooler, figure $150 for that stuff.
total of around $2500 if you can do most of the work yourself. my stock 4l80e with shift kit took me well into the 10's and i think it was the converter that took it out anyways. i would say 700+rwhp in stock form!! then if you do happen to burn one up you can get a super strong one built up from someone like FLT.
Jakejack
Jan 8, 2024 10:44 PM
Oobray
Jun 13, 2022 03:38 AM
OHsixLS3
Dec 27, 2016 09:30 AM
TXsilverado
Nov 26, 2015 10:54 AM
abey15
Jul 13, 2015 02:20 PM
