Best all around posi?
Old Sep 22, 2011 | 06:41 PM
youngbuck's Avatar
Default Best all around posi?
I need a posi unit for my 93 3.42 10 bolt, should I do gears right now also? Imon a right budget an hoped to leave the stock gears for now till more money was available, thoughts?. Truck is my dd sees the track and an a few street pulls. What unit would work the best overall? who sells them for a reasonable price? Truck in sig thanks guys .
Old Sep 22, 2011 | 11:29 PM
Blown06's Avatar
8 Second Truck Club
Eaton certainly gets my vote...or anything that uses clutches. Tru-Trak is garbage in my book, and a locker would be a pain in the ***. O'yea, anything with auburn on it is garbage too.
Old Sep 23, 2011 | 08:48 AM
black4.8's Avatar
everyone will probably say whatever they run and like. tru trac has treated me good and stronger than clutch unit in my mind.
Old Sep 23, 2011 | 08:35 PM
youngbuck's Avatar
What would perform better on the street? Trying to get the power to the ground .
Old Sep 24, 2011 | 07:54 AM
black4.8's Avatar
trutrac from ron's machining is what you want. i think they run about $450. been a couple yrs since i bought mine so they might of went up some.
Old Sep 25, 2011 | 01:51 PM
Slow91z's Avatar
I like my Trutrac, but it locks up real easy...I like it, but some people might not like dragging the inside tire when turning at stop lights.
Eaton's are good too.
Old Sep 25, 2011 | 02:44 PM
Nick3800's Avatar
i got my complete posi unit, gears and master overhaul kit from Rearendparts.com they gave me a pretty good price and next day delivery to my house. i went with an eaton posi, replacement 3.73 ring and pinion from liberty gear and the overhaul kit was from timken.
Old Sep 25, 2011 | 03:06 PM
tarinitup's Avatar
9 Second Truck Club
+1. I've been running my eaton posi through 5 years of hell and it keeps going.
Old Sep 26, 2011 | 10:13 AM
hog's Avatar
hog
Be forwarned that Eaton now makes quite a of these traction aids.
Eaton LSD with clutches,. Eaton refers to this clutch style as the "LSD Posi" comes stock with 400lb preload clutch springs, 200 lb and 800 lb. preload springs are available. The 200 and 400 lb preload springs use teh carbon fiber clutches, but the 800 lb preload springs do NOT use carbon fiber clutches.
The Eaton Detroit Truetrac uses no clutches, but uses gears and torque bias adjusts based on available traction. If 1 wheel is in the air, the ebrake may need to be applied in order to move the vehicle. This type of traction aid has the ability to apply power to the ground when coming out of corners under power.
The Eaton Detroit Locker is a true locker, and will ratchet when cornering. It will also affect steering tracking when taking gentle bends that arent sharp enough to cause the locker to unlock and ratchet. The truck feels like it wants to go straight and fights your steering inputs.
The Powertrax lock rite is very similar to the Detroit, except it simply replaces sider and side gears and an open dif. is required in order to be able to install it. The Lock rite introduces substantial slop into teh drive line, while driving in a lower gear like 1st or 2nd and you apply and release the throttle there is play in the rearend. Since this unit is installed in a stock carrier, no strength benefits are realized unlike teh others that use an aftermarket carrier which adds strength. I went through 3 Lockrites, and busted 1 stock carrier in 1/2.
If the stock G80 Gov lock was stronger and more predictable in its application and release, it would be a great traction aid.
The Trailblazer SS uses a 14 bolt 9.5" semi float rear, and uses a clutch type LSD. IIRC it is RPO G86 although I have never actually seen a G86 unit, I ASSUME its similar to the Eaton carbon clutch style LSD.
Here is a pic that compares the Eaton Trutrac against a stock GM 8.5/8.625" open carrier. Substantial strength differences.
If I am understanding this correctly, the Auburn cone type LSD is NOT rebuildable. There are a couple types.
542022, High Performance Series
542052, Pro Series - Large bearing hub -
unit includes differential bearings
Applications: All GM products with
8.5 & 8.6 ring gear
Ratios: 2.73:1 & Up
Side Gear Spline: 30 Teeth
Model Years: 1989-1998
542022, Bearing Cone: LM501349
Bearing Cup: LM501314
542052, Bearing Cone: LM102949
Bearing Cup: LM102911
Special Note: Bearings provided with 542052, Pro Series Unit
542097, High Performance Series
- 1999 to Present
542052, Pro Series
8.5 & 8.6 ring gear.
Ratios: 2.73:1 & Up
Model Years: 1999 - Present
542097, Bearing Cone: LM603049
Bearing Cup: LM603012
542052, Bearing Cone: LM603049
Special Note: Bearings provided in 542052, however if vehicle is 99 model year or newer, bearings will not be used. Use bearings specified above.
Some of these electric of air actuated lockers may be the answer, but they appear to be on/off with no in between. They are also quite a bit more expensoive.
peace
Hog
Old Sep 26, 2011 | 01:19 PM
budhayes3's Avatar
PT's Slowest Truck
Good post hog, lots of good info right there
Soooo...what unit would be better for a vehicle that likes the twisties vs. one that's always seeing the 1320?
