Is this balljoint installed wrong?
Old Jan 23, 2012 | 03:18 PM
CashDudeHomie's Avatar
Default Is this balljoint installed wrong?
This is a Moog balljoint on a 2001 Silverado 2wd. The dot is on the left side. Is this installed wrong? Is it a safety hazard? Thanks.
Old Jan 23, 2012 | 04:44 PM
livefast1's Avatar
Yes. Upper balljoints on these trucks have notched sockets. If you let it fly the suspension will bind and eventually break.
Old Jan 23, 2012 | 06:33 PM
Suburbazine's Avatar
Yes it is a safety hazard. Like livefast said eventually it will break and you'll have a wheel folded over stuck under your truck.
Old Jan 23, 2012 | 06:38 PM
Thanks. Let's hope this mechanic will own up to his mistake. He said on the phone that they can be installed in any direction. I don't know how he missed the huge WARNING tag that was attached to the balljoint in the original packaging. He got lucky on the other side I guess because it's aligned.
Old Jan 23, 2012 | 06:44 PM
BTW I don't like to let anyone else work on my family's vehicles, but those &$&@@ lower joints would just not break loose for me. So I just said F it and let him do all 4.
Old Jan 23, 2012 | 07:10 PM
2000chevysilverado's Avatar
I've heated the a-arm with torch before to get them out
Old Jan 23, 2012 | 07:57 PM
livefast1's Avatar
If your not using an impact gun on the ball joint c clamp your probably going to have to periodically whack the clamp with a bfh. Most times I will just pound the lowers out and only use the tool to install the new ones.
Old Jan 26, 2012 | 01:18 AM
Well, the guy apologized and fixed it for free - as he should have. Thanks for the replies!
Old Jan 26, 2012 | 12:58 PM
brandon_6667's Avatar
Good to hear
ferrellrooster
Mar 6, 2025 03:22 PM
2500ZL1
Jan 25, 2016 06:30 AM
1bad2k
Aug 26, 2015 07:42 AM
Cammed4ever
Aug 20, 2015 10:47 AM
Mzay
Jul 6, 2015 11:03 PM
