Bad vibrations at 35-42
Old Jun 29, 2009 | 02:08 PM
lownslo's Avatar
Default Bad vibrations at 35-42
I have a bad vibration and i can't tell if its my radials out of balance or my swing carrier bearing? I put the relocator from belltech on my truck when i did the 2/4 drop and it has never done this? have you guys experienced this with your truck before? I am going to put the other tires back on tonight and see if it still does it?
Old Jun 29, 2009 | 03:32 PM
nonnieselman's Avatar
your truck is cursed....
Old Jun 29, 2009 | 03:55 PM
Atomic's Avatar
I have a gauge for that
I say tires. Any balance problem ive ever had has always been tires. You took off those brake rotor clips right?
Old Jun 29, 2009 | 03:57 PM
i forgot about them lil boogers...
Old Jun 29, 2009 | 03:59 PM
lownslo's Avatar
nah never messed with it but i have never had a balance problem till yesterday and it just started like I lost a wheel weight or my carrier came loose and moved and is allowing the drive shaft to move????? its making me mad ha!
instruct me on the clips!
Old Jun 29, 2009 | 04:04 PM
Atomic's Avatar
they are put on the axles to hold the brakes together during assembly, but arent needed afterward and wont allow aftermarket wheels to sit flush with the flange, but since you have stockers, that is probably not the problem.
any play in the driveshaft? could be the rear ujoint.
Old Jun 29, 2009 | 04:06 PM
lownslo's Avatar
im going to check it tonight ill put my street tires back on and take off the radials to see! if it still hapens then ill check the drive shaft
Old Jun 29, 2009 | 04:08 PM
Atomic's Avatar
if its none of those, then check for missing tire weights, you can usually see where they were stuck on and if they are missing.
RustyD
May 23, 2016 07:04 PM
00loudchevy
Dec 3, 2015 05:54 PM
dsbodley
Nov 14, 2015 09:46 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
Chevy305
Sep 28, 2015 09:21 PM
