Bad vibrations at 35-42
I have a bad vibration and i can't tell if its my radials out of balance or my swing carrier bearing? I put the relocator from belltech on my truck when i did the 2/4 drop and it has never done this? have you guys experienced this with your truck before? I am going to put the other tires back on tonight and see if it still does it?
nah never messed with it but i have never had a balance problem till yesterday and it just started like I lost a wheel weight or my carrier came loose and moved and is allowing the drive shaft to move????? its making me mad ha!
instruct me on the clips!
they are put on the axles to hold the brakes together during assembly, but arent needed afterward and wont allow aftermarket wheels to sit flush with the flange, but since you have stockers, that is probably not the problem.
any play in the driveshaft? could be the rear ujoint.
lukn4trbl355
Oct 21, 2015 11:19 PM
