Axle leaks
#51
thats what my problem was, but it was leaking bad, coated inside of my old ss rims, and tires, and under truck, nice to clean the rims and not see rearend oil anywheres, you were definitely a lifesaver.(even when staying when I was locked out)
#55
Custm2500's Rude Friend
The first one I got was supposed to be a 3.73 with G-80. Turned out it was swapped at some point and I ended up with 3.42's and an open cairrer. I noticed the pinion seal was leaking but I didn't think it was a big deal. Got it appart and the bearing spun on the pinnion and chewed it up.... Had to use a sledge hammer to get it apart. Turned out to be an expensive housing with axles...
Got my hands on a one recently that was in a fire.... The one axle was tought to get out. I didnt think about it at first but later realized thats the side the Gas tank was on... I am no guessing that the housing warped from the heat... I will have a look at it as soon as I make a set of rings for my line up bar...
2002_Z28_Six_Speed
10-04-2015 01:34 PM
