Axle leaks
Old Aug 14, 2010 | 01:05 AM
  #51
.James.'s Avatar
thats what my problem was, but it was leaking bad, coated inside of my old ss rims, and tires, and under truck, nice to clean the rims and not see rearend oil anywheres, you were definitely a lifesaver.(even when staying when I was locked out)
Old Aug 14, 2010 | 01:08 AM
  #52
Atomic's Avatar
I have a gauge for that
I was getting yelled at from my mom to get that axle out of the driveway so I figured if my 14b was going to break, it already would have by then
That little dog is a hellion haha
Old Aug 14, 2010 | 01:14 AM
  #53
1FastBrick's Avatar
Custm2500's Rude Friend
Did you pull the rear end at the wrecking yard or was it already out???
Old Aug 14, 2010 | 08:43 AM
  #54
Atomic's Avatar
It was already out sitting in the yard with all the other axles. No idea how long it sat there.
Old Aug 14, 2010 | 06:20 PM
  #55
1FastBrick's Avatar
My thought was that it may have come out of a wrecked truck. Its possible that the housing is slightly bent. or you could have just got one that was poorly maintained and is just worn out...
The first one I got was supposed to be a 3.73 with G-80. Turned out it was swapped at some point and I ended up with 3.42's and an open cairrer. I noticed the pinion seal was leaking but I didn't think it was a big deal. Got it appart and the bearing spun on the pinnion and chewed it up.... Had to use a sledge hammer to get it apart. Turned out to be an expensive housing with axles...
Got my hands on a one recently that was in a fire.... The one axle was tought to get out. I didnt think about it at first but later realized thats the side the Gas tank was on... I am no guessing that the housing warped from the heat... I will have a look at it as soon as I make a set of rings for my line up bar...
Alco
Jul 20, 2016 04:53 PM
03sierraslt
14
Oct 9, 2015 05:53 AM
2002_Z28_Six_Speed
Oct 4, 2015 01:34 PM
02AWDAWSDenali
Oct 1, 2015 05:08 PM
twake_410
Sep 25, 2015 10:09 PM
