AWD front end noise
Old Apr 14, 2009 | 07:33 PM
TURBHOE's Avatar
Default AWD front end noise
just got back from a trip to Arkansas from Maryland and back. on my way back i came to a rest stop, and when i turned hard the whole truck vibed real bad. like if it had a locker in the front end. at first i thought it was my detroit in the rear but you could feel it in the front. also when i get on it there is a loud pop noise from the front.
Old Apr 14, 2009 | 10:21 PM
Thats a little weird unless something let loose in the front. What t-case are you using. The center diff or viscus clutch could have locked or seized causing a 4x4 feeling.
Dont know, just bouncing some ideas.
My front diff just let loose but it only howled really bad, enough to give me a headache.
Old Apr 14, 2009 | 10:33 PM
budhayes3's Avatar
PT's Slowest Truck
Maybe one of the carrier bearings took a dump and the front diff is moving around? Or the pinion nut loosened up?
Old Apr 14, 2009 | 11:16 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
I've seen alot of front diff. carrier bearing adjuster lock-tabs break off, and allow the bearing adjuster to back off. Causes catastrophic damage in the front diff. If you noticed the problem before the front diff. eats itself apart, you have saved yourself alot of money. To me, it's worth dropping the front diff. to check it out.
Old Apr 15, 2009 | 12:07 AM
vanillagorilla's Avatar
Check the CV's and axles first, before you spend the time dropping the front diff. Also you can pull the front DS off and rotate the diff by hand. You should be able the feel/hear if it's taking a dump on you.
Old Apr 15, 2009 | 10:16 AM
TURBHOE's Avatar
its the nv149 case. i took the borg warner case out. i think the front was going before the case swap. but it never made this noise. after it cooled off the noise isn't there but there is a slit whine while turning sharp. i'm going to drain the fluid and check it out. the pop noise while wot worries me. use to with the old case it would just go striaght to red line when it did this. but now it keeps going.
Old Apr 15, 2009 | 07:49 PM
TURBHOE's Avatar
where is a good place to get a rebuild kit? or do i need a full kit? i need to read my book and see how this diff works i guess. how would a person know if it was the cv's?
Old Apr 17, 2009 | 12:04 AM
You need to pull it out and assess the damage before you order parts. If it is what it sounds like to me, then you'll save money buying a used diff.
Old Apr 17, 2009 | 10:36 AM
thats what i did, it was worth the money not wasting time and having down time on the truck just to buy a used one. now i have a back-up diff just in case and am planning on rebuilding it in spare time
i spent 600 on mine from a member here
Old Apr 17, 2009 | 11:15 AM
TURBHOE's Avatar
well i'm making sure its the problem before i buy anything this time. i spent around a grand replacing my lifters and it wasn't the problem at all. i'm wondering if it wasn't the viscous coupler driving the front too much. if it gets heated up it will cause this. also i wonder if the loud pop i hear is not just a inner cv joint. it only does it under boost. if i brake stall it, when it rolls into boost it will pop real loud.
