Anyone using Jake's 4L80e Rebuild Kit?
Old Apr 4, 2018 | 08:03 PM
lxcoupe's Avatar
Default Anyone using Jake's 4L80e Rebuild Kit?
Hey all, wondering how the Jake's Lvl 2 rebuild kit shifts? I only have experience with a factory 80e with a Transgo in it and that trans shifted awesome at WOT and part throttle 2-3 and 3-4 but the part throttle 1-2 shift was a little bit harsh. I'm wondering what a Jake's kit would feel like? I'll be having my local trans shop do the rebuild on a core I sourced.
Old Apr 5, 2018 | 09:19 AM
darkirish63's Avatar
Used a Jake's Stage III rebuild kit on my donor 80e. I have about 7,500 miles on it now & has performed flawlessly. No complaints.
Old Apr 5, 2018 | 12:31 PM
lxcoupe's Avatar
How does it shift? Nice and firm or do you wish it shifted harder?
Old Apr 5, 2018 | 03:28 PM
The shift firmness is really set by your tuner in the end. Mine had mine hitting pretty hard from 1-2 but I had him soften it up just a tad. I was chirping the tires everytime and it was just getting annoying. Still hits pretty hard but the tires don't chirp unless I want them to 😎
Old Apr 5, 2018 | 03:37 PM
TXsilverado's Avatar
you should have talked to your tuner about that harsh part throttle 1-2.
Old Apr 5, 2018 | 06:25 PM
madmann26's Avatar
Not running Jake's kit...
My tune had the stock upshift pressures and I had an annoying 1-2 tire chirp.
I pulled all the upshift pressure out, it still did it.
I had to modify the force motor table to get the shift firmness like I wanted.
Mine is a stock'ish rebuild with the internal dual feed mod done.
Old Apr 5, 2018 | 06:30 PM
lxcoupe's Avatar
Transgo shift kit I assume? What did you drill the separator plate to
Old Apr 5, 2018 | 06:34 PM
madmann26's Avatar
No idea tbh. After I sourced my 80e and that went south, I took it to a local guy. My only request was the internal dual feed mod and with whatever else he did, I don't have any issues out of it.
The local guy sourced his own core and built it. I know he used BW clutches in it.
Old Apr 5, 2018 | 06:35 PM
lxcoupe's Avatar
He wouldn't use your old core?
Old Apr 5, 2018 | 10:08 PM
madmann26's Avatar
Nope. It had 10miles on a fresh build and all I could get from it was limp mode.
It did it before and after the rebuild. We suspected a cross leak some where.
douniasg
Feb 19, 2016 06:34 AM
v502
Mar 26, 2013 12:01 AM
BigDawgChevy
Jan 11, 2011 10:49 AM
TURBHOE
Aug 3, 2008 07:15 PM
