Anyone using Jake's 4L80e Rebuild Kit?
Hey all, wondering how the Jake's Lvl 2 rebuild kit shifts? I only have experience with a factory 80e with a Transgo in it and that trans shifted awesome at WOT and part throttle 2-3 and 3-4 but the part throttle 1-2 shift was a little bit harsh. I'm wondering what a Jake's kit would feel like? I'll be having my local trans shop do the rebuild on a core I sourced.
Originally Posted by lxcoupe
(Post 5435731)
How does it shift? Nice and firm or do you wish it shifted harder?
(Post 5435793)
(Post 5435731)
you should have talked to your tuner about that harsh part throttle 1-2. |
Not running Jake's kit...
My tune had the stock upshift pressures and I had an annoying 1-2 tire chirp. I pulled all the upshift pressure out, it still did it. I had to modify the force motor table to get the shift firmness like I wanted. Mine is a stock'ish rebuild with the internal dual feed mod done. |
Originally Posted by madmann26
(Post 5435825)
(Post 5435826)
Transgo shift kit I assume? What did you drill the separator plate to
The local guy sourced his own core and built it. I know he used BW clutches in it. |
(Post 5435828)
No idea tbh. After I sourced my 80e and that went south, I took it to a local guy. My only request was the internal dual feed mod and with whatever else he did, I don't have any issues out of it.
(Post 5435829)
He wouldn't use your old core?
It did it before and after the rebuild. We suspected a cross leak some where. |
