Any tips or tricks for removing leaf spring bushings?
Old Mar 15, 2012 | 11:45 AM
BlackGMC's Avatar
Resident Retard
Default Any tips or tricks for removing leaf spring bushings?
I will be replacing my leaf spring bushings this weekend. Just wondering if anyone has some advice or tricks to aid in the removal
Old Mar 15, 2012 | 11:59 AM
Mangled03gmc's Avatar
Baltimore Whore
A socket that is about as big as the bushing, beat the **** out of it with a hammer.
Old Mar 15, 2012 | 12:00 PM
nonnieselman's Avatar
Got a torch ?
We used a press. And have used a torch before.
Old Mar 15, 2012 | 12:04 PM
BlackGMC's Avatar
Resident Retard
Yep i got a torch no press thou.
Sooo socket, hammer, torch and some ****.
Old Mar 15, 2012 | 12:09 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
The torch works well, it just smells horrible. The socket method sucks, you've got to beat the **** out of it.
Old Mar 15, 2012 | 12:26 PM
BlackGMC's Avatar
Resident Retard
Ya I am expecting it is going to take awhile... Hopefully adjusting the pinion angle, new poly bushings combined some kind of traction bar helps my vibration under heavy load at speed...
On a side note, i called smith racing about the assasin bars, they are releasing a newly designed bar for our truck next week... He said that they have been flooded with orders so they decided to redesign the rear mount.. Previously he said they just welded some brackets on the stock mount, now they are redesigning it...
Old Mar 15, 2012 | 12:47 PM
03regcab sierra's Avatar
Yep torch em out. I had no luck with the press or socket and hammer method
Old Mar 15, 2012 | 01:17 PM
Baltimore Whore
You guys are ******. They pop rite out with the old socket and BFH trick
Old Mar 15, 2012 | 01:18 PM
JFOLM's Avatar
I would torch 'em. Lube the new ones good.
Old Mar 15, 2012 | 01:30 PM
sprayedenali's Avatar
Press. It took me about 5 minutes to do all four. I'd say it's be worthwhile to find a shop that'd do it for you for some beer money
