99' crank= longer, spacer? for flexplate?
Old Apr 27, 2009 | 06:59 PM
2 tone 02's Avatar
99-00 have the longer crank, after that they used the shorter crank (same length as the 4.8/5.3)
If you are building a 99-00 6.0L you can swap out crankshafts to the shorter one. If it was me I'd just build an 01+ 6.0 if you haven't spent alot of money!
Old Apr 27, 2009 | 09:17 PM
Low_LSX's Avatar
Formerly Low_LQ4 - 6/6/10
I had a 4l60e behind my 00 6.0. I used the old 5.3 flexplate with new holes on it to mate to the 6.0. The 60E only lasted 1 yr though.
Old Apr 28, 2009 | 09:29 PM
lo&sloSierra's Avatar
will a nv3500 the five speed that came in the trucks work behind the longer crank? or one out of a s10 or something?
Old Apr 29, 2009 | 12:14 AM
Low_LSX's Avatar
I wish I could help but I don't know the answer to that one. But I think it will work. Just measure the distance between tranny's or even better search for 4l80E length compared to a NV3500 I'm sure you'll come up with something.
Old May 23, 2009 | 09:02 AM
will a TH350 go behind this crank without any bs.
Old May 23, 2009 | 01:04 PM
Camaro Zach's Avatar
Originally Posted by KySilverado
If it has the long crank you CANNOT use a 60e behind it.
Edit: Possibly with a custom built converter.
you can run a 60e behind it.. just drill the 80e flexplate to the 3 bolt 60e pattern and do not use the spacer.
Old May 24, 2009 | 05:13 PM
thanks man
Old Aug 20, 2010 | 05:48 AM
droppedchev's Avatar
i did a 02 6.0 swap into my 00 4.8 i used the stock nv3500 with the spacer on the crank and everything mated perfect
Old Aug 28, 2015 | 07:24 PM
redboy skinning squirrels's Avatar
Registered User
PLEAS HELP I have a 03 6.0. trying to replace it with a 01. I bought the spacer from gm that was suppose to pick up the slack. Its spinning the starter but somehow not enough to allow the bendix to return after kicking out.Anybody had this issue or can help?
Old Aug 28, 2015 | 08:49 PM
George C....'s Avatar
Formerly ScreamingL
using the correct starter?
