99' crank= longer, spacer? for flexplate?
im in the middle of a build with a 99' 6.0 crank, is there a spacer or something that will let me keep my 03' 4l60e
If it has the long crank you CANNOT use a 60e behind it.
Edit: Possibly with a custom built converter. |
Originally Posted by KySilverado
(Post 4187503)
o, i thought there was some sort of spacer that was made so you could use a 60e
Originally Posted by lo&sloSierra
(Post 4188052)
a grinder :D
what about any year 4l80e? the nv3500 5 speed? which years of these two will work?
Does the longer crank only come in the 99-00 6.0's? say a friend has a 99 with a 5.3.. will a 03 6.0 be a direct bolt on?
Originally Posted by blazinblue
(Post 4188416)
(Post 4190141)
Any 4l80e 99+ will work with the LQ4 and the longer crank. |
