99-07 4WD Front Coilover Conversion
Old May 13, 2014 | 05:02 PM
  #141
EGrippe77's Avatar
With factory control arms and spindles can I get 3 inches of drop with just the coilover conversion?
Old May 13, 2014 | 06:55 PM
  #142
Atomic's Avatar
I have a gauge for that
Yea, I would say so! What does your current setup measure from the center of the wheel straight up to the top of the fender well?
Old May 13, 2014 | 08:38 PM
  #143
EGrippe77's Avatar
Looks like it's 22" from the center of the wheel to the fender lip.
Old May 13, 2014 | 08:55 PM
  #144
Atomic's Avatar
You have a tahoe? The fender is a bit different than the trucks. A tahoe guy with my kit is sitting at roughly 16" right now, so there is plenty of room for what you want.
Old May 13, 2014 | 10:04 PM
  #145
EGrippe77's Avatar
So I should be able to get the ride height I want with the Pro-Comp shock adapter and not have to mess with the stud mount?
Old May 13, 2014 | 10:38 PM
  #146
Atomic's Avatar
Correct. If you take a measurement from the lower shock bolt to the upper shock hoop thing i can tell you what springs and shocks youll need.
Old May 19, 2014 | 02:34 PM
  #147
EGrippe77's Avatar
Could you tell me what shocks and springs I will need in the rear also to achieve a 5 inch drop? If so what measurements do you need?
Old May 19, 2014 | 02:35 PM
  #148
EGrippe77's Avatar
I will get measurements tonight.
Old May 19, 2014 | 08:14 PM
  #149
Atomic's Avatar
Im afraid i cant comment at all on the tahoe rear setups, dont know much about them. You can try the tahoe forums though.
Old May 20, 2014 | 01:19 PM
  #150
MaddogJP's Avatar
Registered User
Has anyone tried a airbag setup with this conversion?
