9 inch swap?
Old Dec 22, 2013 | 10:42 PM
loganauld's Avatar
Registered User
Default 9 inch swap?
Has anyone done a ford 9in swap in an obs chevy truck? If so what does it all involve? A buddy offered me one for like 100 dollars so i was curious as to the benifets of the swap
Old Dec 24, 2013 | 12:47 AM
1FastBrick's Avatar
Custm2500's Rude Friend
It has been done but it is not a direct swap. You have to have to weld on leaf spring perches at the correct angle. They also have a different wheel bolt pattern.
The benefit would be that the axles are captured in the rear end un-like the 10 bolt that uses a c-clip to retain the axle. Also the Gear is much larger and thicker and can handle more torque.
Old Dec 24, 2013 | 02:16 AM
silverado.408's Avatar
Also curious in this as well. A little work isn't hard
Old Dec 25, 2013 | 01:14 PM
loganauld's Avatar
Registered User
Yeah i dont mind the welding and im getting new wheels for bigger tires anyways but will i have problems with the driveshaft length?
Old Dec 25, 2013 | 01:22 PM
1FastBrick's Avatar
You will have to probably get it shortened as well as change the bearing.
Old Dec 30, 2013 | 07:45 PM
Sierra1320's Avatar
I actually talked to RPM Transmissions in Indiana about doing a Fab 9 in my rcsb GMC. Wouldn't be a problem. Drill the flanges on the axles, weld the spring perches on, set pinion angle, new driveshaft, and modify the existing brakes or plumb with a new rear brake setup.
Old Dec 30, 2013 | 11:00 PM
1FastBrick's Avatar
Existing rear brake's from a truck Won't fit on any of the available bolt patterns available for housing ends. They also won't work with the axle bearing retainer.
To build one from scratch your looking at an easy $3500.
You could modify a stock housing alot cheaper but you still need different brakes and you will have to drill and modify them to work with 6 Lug or swap to five lug rims.
Old Jan 2, 2014 | 08:09 PM
Sierra1320's Avatar
I'm referring to getting a set of axles specifically for a Ford 9" and drilling those axle flanges for the 6-lug bolt pattern of the truck. Also, have to use a new brake setup or use a rear brake system from an explorer which can be purchased new. Either way it would have to be new since the factory components on the truck currently would not work regardless.
Old Jan 2, 2014 | 08:30 PM
1FastBrick's Avatar
I said nothing about the axle shafts. Only that the current stock silverado brakes will not bolt up to any of the available housing ends. And you would still have to modify the Explorer rear brakes for the 6 lug which means you will probably have to pay someone to weld and re-drill the pattern.
Bluecollar Hotrods
Jun 11, 2024 11:37 PM
SloSVO
Aug 11, 2015 07:33 PM
LoneSStar
Jul 27, 2015 09:27 PM
Suburban2500
Jul 19, 2015 04:50 PM
Suburban2500
Jul 13, 2015 09:57 AM
