80 swap with autotrac trans-case
Old Mar 10, 2015 | 08:40 PM
4WDFTW's Avatar
Default 80 swap with autotrac trans-case
Ok I have looked and maybe over looked, but I have a few questions on my 4l80 swap. My truck is a 2003 Single cab short bed 4wd with the autotrac T-case.
1.what input shaft do I need to use my stock T-case?
2. Does any one have the front and rear drive shaft lengths?
3.will the 80 T-case adapter work with the autotrac?
Old Mar 12, 2015 | 09:08 AM
4WDFTW's Avatar
Anyone done this swap?
Old Mar 12, 2015 | 12:46 PM
tgui's Avatar
32 spline input shaft Part number 19019 for transfer case.
HD truck front driveshaft.
If you don't have a 4wd trans you need this adapter:
4WD 5'' trans output shaft. 91-96 need the oil hole. Newer can't have it.
1 13/16 shorter rear driveshaft.
Modified cross member moving trans mounting point back 2.5 inches.
Please search for other threads. There is a ton of info out there.
https://www.performancetrucks.net/fo...d-pics-488060/
https://www.performancetrucks.net/fo...length-431836/
Old Mar 12, 2015 | 07:10 PM
4WDFTW's Avatar
Thank you for the info, I'm familiar with the swap just have never done one with a autotrac T-case. That was my question if the Autotrac requires anything diffrent from the other cases, iv been told it needs a diffrent input shaft.
Old Mar 12, 2015 | 09:47 PM
tgui's Avatar
Yeah, just the 32 spline
I'm learning all this along the way to my eventual swap. I still need to finish my trans rebuild. Also, Atomic provided a ton of good info
Perhaps you'll be able to answer my trans/tuning questions in the future!
Old Mar 12, 2015 | 09:55 PM
GREENSIERRA's Avatar
I have done the swap.
like mentioned you will need a 32 spline input shaft for the tcase along with the tail housing adaptor.
my local trans shop had both of the items in stock and cheap
Old Mar 13, 2015 | 01:07 PM
4WDFTW's Avatar
Ok thanks guys like I said I was told the autotrac needed a diffrent input shaft.
Old Mar 13, 2015 | 01:40 PM
AKlowriderZ71's Avatar
11 Second Hall Moniter
You will also need a pilot bearing to install into the new 32 spline input gear.
Old Mar 13, 2015 | 03:09 PM
tgui's Avatar
I had no idea. You're a life saver.
Do you have a part#?
Old Mar 13, 2015 | 07:59 PM
4WDFTW's Avatar
x2 on the part number I didn't even think of that thank you!
