700-r4 BUILD!!
Old Apr 12, 2006 | 12:11 AM
01fastz28's Avatar
Banned
Default 700-r4 BUILD!!
Hey guys...
If you havent seen my motor post!! Im building a motor that is goingn to hold around 20+ psi in a 1983 silverado.
The motor is a sbc 350...
Now.. Im going to need to build the trans to hold the power...
I have never dealt with an older transmission!!
I am used to the 4l60e...
What is a good build sheet that I would need to get to build i t right!!
Thanks
Old Apr 12, 2006 | 09:52 AM
In my personal experience, the only way a 700r4 will hold up to any real power is to make it reverse manual valvebody.
I have a 700r4 ( rmvb) in my 99 silverado ( procharged @ 15lbs boost). Retaining the fully automatic features, it would start slipping about 2000-2500 miles. Now that it's RM, I haven't had a problem yet ( around 10k on it and 20 track passes....12.10-12.40 neighborhood). I have alto reds for 1st and 2nd and the Z-Pak for 3/4. Everything else is the standard for 4l60/e's: sunshell, hardened input ( and output if you can find one), hardened reaction carrier shell, 5-pinion planetaries, hardened ( 300m) band pin, NO thrust washers ( all torrington bearings), billet servos for 2nd and 4th, etc.
Old Apr 12, 2006 | 10:20 AM
What are your intentions for this truck? Street/Drag and don't care about economy, or do you want an economy car.
Old Apr 12, 2006 | 11:17 AM
01fastz28's Avatar
Banned
Economy does not matter!!!!!
Old Apr 12, 2006 | 11:18 AM
01fastz28's Avatar
Banned
if you dont think the 700-r4 is a good choice, then what about another transmissions!! like a turbo 400...
Old Apr 12, 2006 | 07:04 PM
nightrunner's Avatar
Mr. Obvious
exactly, a built 400 turbo will handle anything... the 700r4 is the weakest pre-4l60e transmission you can get
Old Apr 13, 2006 | 07:18 PM
A built 400 is the way to go, and you also have more part choices with the 400.
Old Apr 15, 2006 | 03:47 AM
zippy's Avatar
What kind of power level are you looking for?
Old Apr 15, 2006 | 07:06 PM
James B.'s Avatar
TH400's are also very easy to rebuild. You can do it with normal tools and a set of feeler guages.
I rebuilt the one in our Demolition Derby '79 Cadillac here at work. It was easy as I've abused the hell out of it since.
MOBBN
Sep 22, 2015 08:07 PM
2500ZL1
Sep 12, 2015 03:50 PM
MA$TER_E
Sep 9, 2015 03:14 PM
iregret
Sep 7, 2015 01:20 PM
