6L80 not installed - Need info please
Old Dec 5, 2016 | 09:28 PM
UV231 Project's Avatar
Default 6L80 not installed - Need info please
If you have a 6L80 not install can you please get a measurement for me.
I am looking for the length from the mounting surface of the bell-housing to where the tail housing bolts or mounts to the case.
Thank you ahead of time.
Sincerely,
Old Dec 5, 2016 | 09:34 PM
arthursc2's Avatar
https://www.powertraincontrolsolutio...Dimensions.pdf
Hopefully helps
Old Dec 5, 2016 | 10:12 PM
Thank you Arthursc2.
Old Dec 5, 2016 | 11:09 PM
07Softail's Avatar
The measurement from the face of the bellhousing to the back of the case is the same for al 6L80's except the vette. Combine A and B mesurments and they are exact. Im not sure what measurment your looking for if this is not it.
RT
Old Dec 6, 2016 | 06:36 AM
I guess I have to go with that and hope that wherever the info came come it is right.
Old Dec 6, 2016 | 11:27 PM
Wolftrk99's Avatar
If i can find time to get to my spare and get the measurement for you, i will.. i had taken the measurement at ome point to compare to the 4l60 and wrote them down and cant remember where, but iirc the link above was spot on to what i had measured...
Old Dec 7, 2016 | 07:17 AM
Thank you Wolftrk99.. The engine compartment I have to work with on my project is not like most engine compartments, it is very restrictive and in the rear of the vehicle. That is why I ask so many questions. I need to be extra sure things will fit and work before I spend the money buying the components that are not returnable. It will also give me peace of mind.
Thank you again,
Old Dec 7, 2016 | 09:39 AM
CF7GO's Avatar
I can get you the info if you'd like. Mine is out and apart...
Old Dec 7, 2016 | 10:03 AM
CF7GO, Thank you. That would be great! If you can put a level at the end the case (without the tail housing) and hook the tape measure on the mounting surface of the bell-housing and measure back to the level that would give me what I need.
Old Dec 7, 2016 | 12:34 PM
07Softail's Avatar
23.25"
rt
