6L80 not installed - Need info please
If you have a 6L80 not install can you please get a measurement for me.
I am looking for the length from the mounting surface of the bell-housing to where the tail housing bolts or mounts to the case.
Thank you ahead of time.
Sincerely,
Sincerely,
The measurement from the face of the bellhousing to the back of the case is the same for al 6L80's except the vette. Combine A and B mesurments and they are exact. Im not sure what measurment your looking for if this is not it.
RT
RT
If i can find time to get to my spare and get the measurement for you, i will.. i had taken the measurement at ome point to compare to the 4l60 and wrote them down and cant remember where, but iirc the link above was spot on to what i had measured...
Thank you Wolftrk99.. The engine compartment I have to work with on my project is not like most engine compartments, it is very restrictive and in the rear of the vehicle. That is why I ask so many questions. I need to be extra sure things will fit and work before I spend the money buying the components that are not returnable. It will also give me peace of mind.
Thank you again,
Thank you again,
CF7GO, Thank you. That would be great! If you can put a level at the end the case (without the tail housing) and hook the tape measure on the mounting surface of the bell-housing and measure back to the level that would give me what I need.
