5 Speed guys ever do the drill mod?
Old Jul 24, 2009 | 02:50 PM
  #21
PathfinderJr's Avatar
Originally Posted by zebra86
just pulled it off today while the engine's out. the fluid reservoir sits directly on the m/c & it's a plastic line that goes from the m/c to almost the bottom of the firewall. then there's a coupler that connects it to braided line that goes the rest of the way down to the slave. i saw the parts-counter schematics that showed it's two pieces, but the thing is that that plastic line it heat-fitted to the braided line when it's assembled, so it ain't coming apart (that i know of).
would a full braided line from a 4th gen z28 work? i know the slaves are the same & i think the m/c are too.
Ooooh, ok. Guess I'm not remembering correctly. It has been a while since I've taken a look at mine in detail. I don't see why a braided line from a 4th gen won't work as long as the length is there. Check out the T56 swap thread, cause I know they got info on what parts to use there, and obviously they'll work in this case as well. You may not be able to just buy the braided line as it may come with the M/C. In that case, I'd just check out some local junk yards and take it off yourself.
Originally Posted by RED04REGENCYRST
the restriction your lookin for is where the braided line connects to the slave. youll have to knock out the roll pin and then the braided line will seperate from the slave. that is the end where you would perform the drill mod.
I'm not so sure, man. Everything I've read about it, including the write-up on that LS1 Install University or LS1Howto page says the restriction is up at the junction to the M/C. And as zebra86 said, there's a quick disconnect at the slave. The roll pin connection is up at the M/C.
Old Jul 24, 2009 | 03:15 PM
  #22
RED04REGENCYRST's Avatar
the truck slave and the f-body slave are setup reverse of each other. with the f-body slave you have the quick connect at the slave. with the trucks with the 5-speed you have the quick connect at the output of the master. the restriction is in the end of the braided line that does not have a quick connect fitting. i did this to my setup. i was a 5-speed and then converted to the t-56. i am still using the truck master and truck slave. i pulled the roll pin out of the slave to disconnect the braided line from the slave and performed the drill mod on that end. there was a restriction about 1/2" in and then another about 1" in.
Old Jul 24, 2009 | 04:11 PM
  #23
I did not know that. Thanks for the info. Learn something new everyday haha.
Old Jul 24, 2009 | 04:44 PM
  #24
1quickRST's Avatar
Just curious, has anybody ever looked into trying to modify the NV3500? It seems like every one just does the T56 swap, which is understandable, but if you could get better synchro's and replace other short comings on this tranny it seems like it would be a good tranny! And probably cheaper than a T56 swap. Just my 2 cents......
Old Jul 24, 2009 | 05:30 PM
  #25
I dunno about it being a good tranny haha. I don't like the gear ratios for one thing. Second to third just blows chunks. And I'd love to be able to cruise down the interstate at like 1700-1800 with some fun gears in back as opposed to my 2200-2300 with just 3.73's. T56 double overdrive ftw.
Old Jul 24, 2009 | 07:33 PM
  #26
i have 4.88 gears and at 80 mph in 6th im at roughly 2000rpms. first and second are mean as hell. i have to get a vid of the truck from a stop soon.
Old Jul 24, 2009 | 10:43 PM
  #27
_zebra's Avatar
makes children cry
are you runnin a f-body slave? did you change out you braided line?
they're the same with my truck. i'm thinking about trying an f-body line, assuming i can find one for cheap
...I don't see why a braided line from a 4th gen won't work as long as the length is there. Check out the T56 swap thread, cause I know they got info on what parts to use there, and obviously they'll work in this case as well. You may not be able to just buy the braided line as it may come with the M/C. In that case, I'd just check out some local junk yards and take it off yourself...
that's the plan. the stealership won't sell one without the m/c
...I'm not so sure, man. Everything I've read about it, including the write-up on that LS1 Install University or LS1Howto page says the restriction is up at the junction to the M/C. And as zebra86 said, there's a quick disconnect at the slave. The roll pin connection is up at the M/C.
this is how it is on my truck - roll pin at m/c to plastic line to braided line to quick-connect to slave cylinder. there is a roll pin at the slave, but it goes to a quick-connect fitting where the line attaches
fbody uses the same setup except the whole line is braided
so apparently GM designers decided to really screw with everybody & create two different versions because, like the pic above shows, that's at least how a 99 nv3500 clutch line works
2200rpm on the highway?! what size tires are you running - 215/75-16s? (or comparable 28.7" tall tire)
that's what the math works out to @ 70mph
are those 4.88s in a 10 bolt or 14 bolt?
Old Jul 24, 2009 | 11:41 PM
  #28
yea it looks like before 03 the trucks may have been running a f-body slave. but after 03 they are set up like i was talking about.
i have the 10 bolt rear end.
Old Jul 26, 2009 | 02:29 AM
  #29
my bad, I must have been remembering what rpm is at 75mph. 275/60/17 tires (30"), 75mph, and .73 final gear for the nv3500. It equates out to roughly 2300rpm.
Old Jul 26, 2009 | 04:58 AM
  #30
JakeBrakeIH's Avatar
my 2000 had a roll pin at the master...its was a 5 speed before...heres the slave...
I dont know if thats a quick coupler like you guys are talking about(maybe use a special tool to release it) but I just knocked out the roll pin to switch it...actually come to think of it I cant really remember its been soo long
