5 lug adapters??
Old Aug 3, 2008 | 12:04 PM
ZQ8Dude's Avatar
Default 5 lug adapters??
I noticed a few people have them, and i have to ask, how strong are they? can you drag race on them?, and does this throw off the offset on your wheels??
Old Aug 3, 2008 | 05:12 PM
viciousknid's Avatar
Where's the Beef?
I always thought the people on here that were running 5 lug didn't use an adapter. I thought they had all filled and drilled a 5 lug pattern.
Who's running the Adapters?
Old Aug 3, 2008 | 05:34 PM
InchUp's Avatar
Of course it "throws off" the offset of the wheels...it's nothing more than a spacer at least 1.25" thick so naturally your tires and wheels will stick out that much farther.
As for their strength, I'd only recommend billet aluminum.
Old Aug 4, 2008 | 05:13 PM
ZQ8Dude's Avatar
i forget his name. i saw pictures of his truck with 5lug drag wheels and 6lug street wheels in the "show off your truck" sticky
Old Aug 5, 2008 | 02:29 AM
Dirty 30's Avatar
LS1Tech Whore
There is no answer to how strong are they. I drive my truck everyday on the street and race it on the weekends. I have done 7.8s at the 1/8th and up to 120 mph with no problems. I cant tell you that I recomend them, this is just what I do in my truck.
https://www.performancetrucks.net/fo...d.php?t=422202
https://www.performancetrucks.net/fo...d.php?t=422069
https://www.performancetrucks.net/fo...d.php?t=398045
Old Aug 5, 2008 | 10:06 PM
ZQ8Dude's Avatar
hmm, do they work with drums?? If so seems like something i'd like to try out for just running drag lites out back.
Old Aug 5, 2008 | 10:48 PM
L7 Sierra's Avatar
I wouldn't run adapters on anything, but if you want 5 lugs here you go.
You can just order new rear axles to correct the 6 lug problem, and many places can re-drill your drums to match.
As far as the front disk I never had mine apart so I am guessing a bit here here.
The front hubs may be a bit thick to get a 5 on 4.75 bolt circle drilled in to them, but a 5 on 5 maybe a bit easier. Either way you'll need to fill in the 6 holes and any stress risers so you 5 lugs will seat correctly.
Old Aug 5, 2008 | 11:14 PM
ZQ8Dude's Avatar
well that wont really work for me since my truck is a chevy colorado and i dont wanna redrill anything. I just hoping for a way to get some cheap(er) drag wheels for this thing while be able to retain the stock wheel setup
Old Aug 6, 2008 | 12:34 PM
Dirty 30's Avatar
LS1Tech Whore
Oh I see, a Colorado might be different then.
SlvrSierra4.8
Oct 7, 2015 09:46 AM
lxcoupe
Sep 25, 2015 12:36 PM
ice17
Sep 22, 2015 05:18 PM
okie454ss
Sep 22, 2015 07:39 AM
99bluefirebird
Sep 17, 2015 08:05 PM
