2nd slave in less then 6 months.
Old Jul 15, 2008 | 09:36 PM
2005 Silverado's Avatar
SPAM HUNTER
Default 2nd slave in less then 6 months.
Was driving home, was about 100 feet from where it went out the first time. Gave it a quick blip through first felt really really strong and spun posi (will do it very randomly if the pavement is a little slick), pushed the clutch knew right away what happened, just let it coast for about 500 feet then called my dad for a tow.
Next mod T-56, wont drive until then i guess back to driving the big block truck
Dustin
Old Jul 17, 2008 | 12:21 AM
SBTork's Avatar
well, that's shitty. I can't say this has happened to me, but my V6 just can't brake anything . So you're in the market for a T56 now?
Old Jul 17, 2008 | 12:31 AM
A Low Dime's Avatar
13 Second Truck Club
On my old truck, my clutch line touched the exhaust and burnt a hole in it. Took it to the shop and had replaced, worked good, but had them bleed it twice. Worked well for lil bit, then lost all pressure, turned out they had made a very small hairline crack around the bleeder valve.
________
Buy bubblers
Old Jul 17, 2008 | 11:28 PM
SPAM HUNTER
It not in the market right away, but i have another car to drive that gets 33+ MPG and i have very little bills to pay, so i can save save save i hope to have alot of it done by winter. Im going to buy a new T56 instead of used, the hardest part is going to be the tuning for the 6 speed.
I haven't had a chance to actually pull the trans yet and see whats up. But it did the exact thing last time, like to the T. To be honest, i wasn't even upset, i cant get mad about something i can't control and i kinda knew was going to happen.
Dustin
Old Jul 17, 2008 | 11:43 PM
charcold-bowtie's Avatar
You have plenty of time till the 13th of dec. GO WORK. Good luck with the fix.
Old Jul 17, 2008 | 11:53 PM
SBTork's Avatar
Really? I wouldn't think the tuning would be too bad. From what I've heard you can just use your regular tune, but no cruise in 6th gear. Maybe a 4th gen F-Body tune will work? are you going through FLT for the T56?
Old Jul 18, 2008 | 10:20 AM
ZZebes's Avatar
Yeah dustin you can just use your stck tune and then adjust the gear ratios in the trans
Old Jul 18, 2008 | 10:27 AM
thunder550's Avatar
High on diesel fumes
Yeah you have to be careful when you're playing with the shift pressure and shift timing tables in the tune. Make sure it doesn't get your line pressure too high, or you'll just blow out another slave cylinder. I'd go with a higher stall clutch this time around too.
Old Jul 18, 2008 | 10:33 AM
kbracing96's Avatar
Old Jul 18, 2008 | 10:34 AM
ZZebes's Avatar
uhhh **** i'm confused
I'm going back to bed
