5.3 TO 6.0 swap
Old 01-29-2018, 11:55 AM
Registered User
patsuburban's Avatar
Default 5.3 TO 6.0 swap
Hey guys thanks for the add. I have an 05 suburban 1500 with the 5.3/4l60. I have access to a 03 gmc 2500hd with the 6.0/4l80. What would it take to swap engines and transmissions? I have access to the whole truck, so wire harness, gauge cluster, etc. Can I just swap computers? Or do I have to get the 5.3 one tuned?
Old 01-29-2018, 12:14 PM
Merctech2's Avatar
If I remember correctly,all you need is motor and tranny. Then need to modify crossmember or buy one, repin harness , tune, and yoke shaft. On my truck I didn’t need to do anything with the driveshaft, don’t know about a surburban
Old 01-29-2018, 01:19 PM
FFDP's Avatar
Being that both are DBW you might just be able to use the 6.0 harness but keep your 5.3 computer and have that tuned for the swap.
A simple copy and paste from a 05 6.0 truck file to match your 05 year for the engine and then a segment swap for the transmission if you are using HP Tuners software.
Old 03-27-2018, 09:48 AM
Registered User
danielshunter87's Avatar
I have a 5.3 2005 im wanting to swap it with a 2008 6.0 is this possible ? Or are those years not compatible with each other?
Old 03-27-2018, 05:11 PM
FFDP's Avatar
Not the same generation engine. 2005 is a GEN 3 and 2008 is a GEN 4. The 2008 has different cam sensor location, knock sensor locations, different crank triggers and cam triggers. 2008 has VVT and all that jazz too.
It would not be a easy or quick swap. Find a LQ4 or LQ9 6.0 engine as those are direct swaps besides tuning.
LOWRIDERGMC (03-27-2018)
zstangboi
01-07-2008 04:47 PM
OrlandoFL4.8
01-28-2006 12:01 PM
mattrem
11
10-14-2005 08:11 PM
01Z71GMC
14
02-21-2004 11:31 AM
gibbs6
07-17-2003 12:12 PM
Quick Reply: 5.3 TO 6.0 swap
