4L80E Transgo Shift Kit Install Help
Old Aug 8, 2015 | 02:01 PM
lycominghunter's Avatar
Default 4L80E Transgo Shift Kit Install Help
I am finishing up the shift kit on my 4L80e. Im in the process of finishing up the transgo HD-2 shift kit on my 4l80e. I replaced the spring for the reverse/low servo piston per the transgo instructions. When I reinstall the piston into the trans, I don't believe that the servo piston is pushing into the trans as far as it should be. The piston is seated up in the piston housing near the front of the trans, however the piston face is slightly below the piston housing edge towards the rear of the pan. If I try to install the accumulator cover, there is approximately a 1/8 gap between the cover and piston housing faces due to cover to piston contact towards the rear of the pan. I can install the accumulator cover flush with all the bolts with ease, however I believe I remember the piston being farther up in the piston housing when I disassembled. Any help would be greatly appreciated. Thanks!
Old Aug 8, 2015 | 04:12 PM
treylittlefield's Avatar
Got a pic of it?
Old Aug 8, 2015 | 05:20 PM
Yes Sir. I can try to get better pics if need be...
Attached Thumbnails 4L80E Transgo Shift Kit Install Help-rl-piston-1.jpg   4L80E Transgo Shift Kit Install Help-rl-piston-2.jpg
Old Aug 13, 2015 | 07:03 PM
Bump! Still trying to figure this out. Thanks for the help
Old Aug 15, 2015 | 12:26 PM
James B.'s Avatar
The spring pressure is consistent with my experiences with these. Fairly strong spring too, takes force to hold the cover down while you get the bolts in. Doesn't seem like a problem to me.
thunder550
Oct 8, 2015 04:53 PM
1slwgto
Aug 16, 2015 06:40 PM
Ammadien
Jul 22, 2015 08:50 PM
lxcoupe
Jul 21, 2015 02:12 AM
zaathur151
Jul 6, 2015 10:57 PM
