4L80E Swap Crossmember Mod (pics)
yea the 4wd has a different x member too right? It looks like your talshaft bushing is different mount too. Post up some pics when ya get it all in! Are the wires the same for you as a 2wd? ( I had to add a vss sensor and change two pins in the harness that goes into the trans.)
I like the way you did yours as well. It just shows there is more than one way to do things!
For you guys that added a mounting tab to the back of your crossmember, How much clearance to the pan do you have? Can you pull the pan without removing the crossmember? It's not much extra work to support the t-case & remove the crossmember, but I just want to know. Pics of the pan/crossmember would be cool if anyone has them.
Thanks in advance!
Thanks in advance!
