4L80E Swap Crossmember Mod (pics)
3 Attachment(s)
As some of you know, sharpshooter and I are swapping to FLT Level 4-4L80E's. We finished his truck up a couple of weeks ago. I'm in the process of getting my truck cometely ready for when the tranny gets here. Pretty much the only thing I have left to do is the wiring for the speed sensor, which will be done this weekend. I worked on my crossmember today, so I thought I'd post up a few pics. I'll post up more tomorrow after it's painted. I used an 8" piece of 1/4" angle iron. It's welded on the crossmember, and the two holes attached to the crossmember is where 1/2" grade 8 bolts will also help hold it for insurance.
Attachment 144323 Attachment 144324 Attachment 144325 |
Keep your brain open, I am going to be picking it soon, about the wiring and all needed to be done to make the 4l80 a home in the 60 spot..
(Post 4764473)
Hmmm seems to me that option is a lot easier than cutting down the crossmember to extend it. Are you going to install some gussets on the ends and in the middle for "twisting" support.
I think this is 4wd tho^ What your talking about it typically for 2wd where it needs to move 6 inches or so
No, I'm not going to use gussets. I actually made gussets to weld in, but decided against using them. It's 1/4" thick angle iron, it's not going to move. By measurement, the new location of the transmission mount will only be 1 1/8" onto the angle iron.
4 Attachment(s)
I did mine a little different, I just cut and extened it.
Attachment 144326 Attachment 144327 Attachment 144328 Attachment 144329 |
Originally Posted by lownslo
(Post 4764653)
http://i25.photobucket.com/albums/c9...Picture001.jpg http://i25.photobucket.com/albums/c9...Picture004.jpg http://i25.photobucket.com/albums/c9...Picture034.jpg http://i25.photobucket.com/albums/c9...Picture032.jpg |
I'm gunna have to post here so I can remember this cuz I'm sure one day I will be doin it
yea the 4wd has a different x member too right? It looks like your talshaft bushing is different mount too. Post up some pics when ya get it all in! Are the wires the same for you as a 2wd? ( I had to add a vss sensor and change two pins in the harness that goes into the trans.)
