4l80e swap
11 Second Truck Club
any year 4l80e will work, but the 98 and newer are the strongest design, 93-95 are the weakest, 96-97 are decent. I went with an 02 that was a core with worn clutches and had it built. Its easiest to stay with your model year or similar, therefor the NSS and electrical connections are the same, there are 2 plug and 1 plug versions.
The top hole isn't necessary if the trans isn't drilled for it, the older sbc and bbc did just fine without it. I know plenty of people running around without the top bolt anyway because they are too dumb to realize its simple to get in/out from the top of the motor vs underneath.
Cant remember, been quite awhile since i've worked on one. But 6 bolts is plenty, the bolts only hold the trans tight to the engine, the dowel pins align, prevent twist. The trans on boss hoss bikes only have 4 bolts and the one at our shop makes 1100hp and runs 135mph in the 1/8th. Plenty to hold it together.
lycominghunter
07-29-2015 04:24 PM
