4L80E reverse boost valve question
Old Sep 9, 2013 | 12:45 AM
Ferocity02's Avatar
Default 4L80E reverse boost valve question
I bought a Sonnax self-regulating reverse boost valve and installed it and noticed that the inner white spring is loose inside the outer purple spring, it can slide back and forth by about 3/8". I did not notice this when the took the stock valve out. Perhaps it's just because the boost valve is bottomed out in the boost valve sleeve. I just want to make sure I didn't make a dumb mistake.
Also the ATSG manual only shows one spring but mine had two?
Old Sep 10, 2013 | 12:42 PM
Ferocity02's Avatar
Anyone?
Old Sep 15, 2013 | 06:55 PM
Yukon04's Avatar
How did you install that stator bushing with the notch and grooves?
Old Sep 15, 2013 | 07:11 PM
silverz28camaro's Avatar
I do 4l60es all the time, and their reverse boost valve is VERY similar, the inner spring does float around loosely...
ARC
57
Feb 21, 2022 10:54 AM
chopperloco
Jul 10, 2016 10:45 PM
The_W
Oct 28, 2015 09:00 PM
bbowerman
Jul 26, 2015 10:57 PM
zaathur151
Jul 6, 2015 10:57 PM
