4L80E Question
I found an add for a 4 speed auto with tranfer case with 42K miles out of a rolled 2005 3500 crew cab. The guy doesn't seem to know that much about the trans but looked & said the transfer case was electric shift & the he was sure it wasn't an allison.
It is a very good deal but I will have to drive a couple of hours to see it. He said someone already bought the 6.0 engine out of it.
This has to be a 4l80e correct? I am wanting to swap this into my 2000 1/2 ton. If this is an electric shift if should be the auto trac & therefore usable in this swap?
OK, it's a 3500 I assume that's what you meant. I asked if it was a manual or electric shift & he said electric. This transfer case can not be used for my project? What transfer case is this? I will do some more research.
It is a 263HD transfer case. Looks like it came with some 2500 & 3500 pickups.
I am going to buy it, seems like a good deal, $500 for the tranny & transfer case.
Hopefully I can use the transfer case for my conversion.
I have hit a brick wall with converting to the 263 TC, I guess no one has done this. Seems like all you would need is to apply 12v + to engage 4hi/lo etc. but who knows.
I guess I will put a new input shaft on my autotrac. I really didn't want to use it because it has 200k miles on it. It still works so we'll see.
That 263hd case is worth some money, I replaced one in a good friends truck, tough to come by, and the used ones with a million miles are upwards of 700, remanufactured is north of 1k. The autotrac is proven to be a pretty tough case if its in good shape. I will be using one with my reg cab build which will be around 900rwhp.
GXPJAY
Feb 13, 2022 08:15 AM
GXPJAY
Jan 27, 2016 11:45 AM
