4l80e no workie----Trans or converter?
Old Dec 29, 2013 | 09:04 PM
  #31
AJII's Avatar
Originally Posted by AKlowriderZ71
I'm thinking you'll find a broken pump. Not much else will cause 0 psi. You don't have low pressure, you have no pressure at all.
Would it have moved at all the first mile if it was a broken pump? That's the only thing that gives me a glimmer of hope it's not.
  #32
AKlowriderZ71's Avatar
11 Second Hall Moniter
Borrow a gauge.
Old Dec 29, 2013 | 09:05 PM
  #33
Yes it could have. Installation errors often fracture the pump. Then after the pump works & pushes fluid while driving, and pump pressure increases during driving, the fracture becomes a complete break. Then you have 0 psi.
Old Dec 29, 2013 | 09:07 PM
  #34
Circle-D's Avatar
Former Vendor
And just to make sure, this was the 3 lug LS billet front setup - correct?
And like mentioned above, put a pressure gauge on the pressure port. That will let you know exactly what is going on. Next I would pull pan and check filter.
Chris
Old Dec 29, 2013 | 09:08 PM
  #35
AJII's Avatar
Makes sense. Dammit. LOL!
So.....do pieces of broken pump circulate through out the trans? If my 1 mile converter is trashed, my bad night just got worse
Old Dec 29, 2013 | 09:10 PM
  #36
AJII's Avatar
Chris
No, this was your high performance 278mm unit with a 3 lug setup for 80e.
  #37
Circle-D's Avatar
Former Vendor
You get one free cut and clean.... so we got you covered there. But you are correct, a broken pump can send trash into the converter.
Chris
Old Dec 29, 2013 | 09:11 PM
  #38
Circle-D's Avatar
Former Vendor
OK, that is the LS bolt pattern. And just to make sure, you did not use a crank spacer. Bolted the flexplate directly to the crank.
Chris
Old Dec 29, 2013 | 09:14 PM
  #39
AJII's Avatar
Chris
That's good news. Didn't know that. But man...I would have liked to atleast have a good story for having to send it back.
Chris
Nope. No crank spacer.
Old Dec 29, 2013 | 09:34 PM
  #40
chevrolet all the way's Avatar
If the pump or converter was the issue then checking fluid would yield fluid high up the stick. I Put the sonnax self regulating boost valve, and sonnax pressure regulator valve. Only thing i can think of is somehow the snap ring blew out on the boost valve sending all of it into the pan. I would have no clue why or how it made it down the street if it wasnt seated or the valve wasnt in correctly though??
