4l80e no workie----Trans or converter?
#31
#33
Yes it could have. Installation errors often fracture the pump. Then after the pump works & pushes fluid while driving, and pump pressure increases during driving, the fracture becomes a complete break. Then you have 0 psi.
#34
And just to make sure, this was the 3 lug LS billet front setup - correct?
And like mentioned above, put a pressure gauge on the pressure port. That will let you know exactly what is going on. Next I would pull pan and check filter.
Chris
Chris
#36
No, this was your high performance 278mm unit with a 3 lug setup for 80e.
#37
Chris
#38
#39
Nope. No crank spacer.
#40
If the pump or converter was the issue then checking fluid would yield fluid high up the stick. I Put the sonnax self regulating boost valve, and sonnax pressure regulator valve. Only thing i can think of is somehow the snap ring blew out on the boost valve sending all of it into the pan. I would have no clue why or how it made it down the street if it wasnt seated or the valve wasnt in correctly though??
