4l80e conversion premature failure: Beware rear cooler line fitting
I am really glad this thread came up (obviously not for the OP's failure!). I was looking at going to braided SS trans lines and I came across a site that sells custom fittings to accept the AN lines, but I don't think the rear one was extended IIRC.
GMCtrk there is -6 fitting with the extended barb for these units. If you google it you will find it. If you can not find what you are looking for I'll see if I can dig up link for you. Vince
4L60 & 4L80 Trans. Fittings -6 AN
I actually forgot, those don't even replace the cooler fitting, they just clip in with the E clip
That's one of them. There is an actual -6 fitting as well to replace the factory fitting. I have not used these but I like the way they look and they have the correct thread pitch. http://www.sweetperformance.com/prod...&productId=496
Is it this? I've had this link bookmarked for a while
Thats what im using now since im using aeroquip pushlok for cooler lines.
found these on ebay -6, -8, and i could have swore i saw a -10 the other day... Anyways $20 seems cheap to me...
Search "4L80E AN Fitting"
4l80 AN fitting | eBay
