4l80 segment swap..
Old Apr 4, 2016 | 04:20 AM
Flewbyu123's Avatar
Originally Posted by lxcoupe
When you pull your tune off your PCM in HPT it will give you your OS #, for instance 12579405. Just google "12579405 4l80e" and you'll find a bunch of tunes you can grab the trans tune off of for the segment swap. Other than that and running the VSS wires to the PCM, there are no electronic/ programming. What difficulties are you having specifically? Feel free to pm tgui he is the resident 80e swap expert.
I need os 12593058 4l80e swap
Old Apr 4, 2016 | 11:55 AM
Flewbyu123's Avatar
The Os 12593058 is the same number to file I had on it.. So any ideal on the codes I'm getting? Someone told me the Iss is at the rear of the tranny next to the drive shaft is this correct?
Old Apr 4, 2016 | 04:42 PM
tgui's Avatar
Did you splice in a new VSS into the wiring harness? That one goes next to the torque converter. I had to get my connector off ebay.
The original VSS goes at the end with the tail shaft if 2wd, or in the transfer case if 4wd. Also, if 4wd you can plug the tail shaft with a VSS and just not wire it. Thats what I did because I'm lazy.
Can you post all your current DTCs please?
I'm looking into your tune file now.
Old Apr 4, 2016 | 04:52 PM
tgui's Avatar
Use my attached file to swap FROM. Open Menu Compare, select my file. Then do a segment swap. This file has the same OS as yours as is needed.
Select both the trans and trans diag options. Ensure trans type is still 4l80e.
Let us know how things go!
Old Apr 4, 2016 | 05:44 PM
Wolftrk99's Avatar
For clarification... The ISS (input shaft speed) sensor, goes to the front of the transmission, the sensor closest to the torque converter, on 4wd 4l80 the OSS(output shaft speed) sensor is in the transfer case, and typically have a plug in the oss hole of the transmission case. On a 2wd the oss is closest to the tailshaft housing of the transmission,
i have a 4wd on my front porch i will get a better picture of tonight when i get home....
This is a 4wd with the rear plug
You can see both in this pic....on the 2wd
Old Apr 4, 2016 | 06:34 PM
Flewbyu123's Avatar
Ok now getting these codes and also my abs light is now.. what gives
0x10: P0740 - Torque Converter Clutch Solenoid Circuit / Open (Pending)
0x10: P0785 - Shift/Timing Solenoid (SES, Pending, Current)
these are the only codes I am getting... I use this one from the c2500 earlier today.. And after a short drive all of the above come as a code.
Old Apr 4, 2016 | 06:38 PM
Flewbyu123's Avatar
Also my speed and tach are off.. not working right.. tach acting funny and speed is way off..
Old Apr 4, 2016 | 06:51 PM
Flewbyu123's Avatar
new segment
https://www.performancetrucks.net/fo...1&d=1459813225
File Type: hpt
Old Apr 4, 2016 | 07:34 PM
tgui's Avatar
Did you flash it?!
Old Apr 4, 2016 | 07:45 PM
Flewbyu123's Avatar
Originally Posted by tgui
Did you flash it?!
yeah flashed,and licensed.
