4l80 segment swap..
Old Apr 4, 2016 | 08:04 PM
  #21
Flewbyu123's Avatar
I have the ISS hooked up on the torque converter side and the Oss hooked up on the side of the drive shaft and I added that sensor cause this was a 4wd tranny before.. Now its on a 2wd. wht wire is A side tan/blk is B side of ISS. Oss is hook to factory colors grn wire and the wire is purple.
Old Apr 4, 2016 | 08:20 PM
  #22
Flewbyu123's Avatar
this is how I have it wired..
Alternate 1
Or cut white and brown and solder brown wire to remaining white at trans plug
Wire white wire to pin A in speed plug
Tan/blk to pin B on speed plug
Remove pin 79 white wire and move to pin 22
Remove pin 42 and move to pin 23
__________________
Old Apr 4, 2016 | 11:10 PM
  #23
Flewbyu123's Avatar
Update change out both sensors and for a few miles every things seem to be ok, but then the check engine light, abs light came on.. Mph gauge not working right at all.. I drive it slowly moves and stays around 20 are so mph.. 3rd is slipping if I get on it.. but it wasn't going into 3rd anytime before I will baby it cause maybe 3rd is still a little dry... What should I look to next?
Old Apr 4, 2016 | 11:24 PM
  #24
Wolftrk99's Avatar
What codes are you getting now, need pull the abs codes also
Old Apr 5, 2016 | 05:05 AM
  #25
Flewbyu123's Avatar
when I turned off the truck and started it again, all the lights were off. I will check if there are any codes.
Old Apr 5, 2016 | 07:41 AM
  #26
Wolftrk99's Avatar
They should be stored in history codes, not sure what kind of scan tool you are using, but some code readers dont read abs and you need to see whats going on with the abs light
Old Apr 5, 2016 | 07:57 AM
  #27
tgui's Avatar
Enable all trans related dtc and make all of them MIL on first error.
DTCs (P0500, P0608, P0700 to P0724, P0740 to P0757, and P1504)
Also log both VSS speeds to see if you're getting a signal. I found my ABS light didn't clear until after both VSS were working and then driving on them for a bit.
Old Apr 5, 2016 | 01:29 PM
  #28
Flewbyu123's Avatar
OK, I'm using the MPVI PRO.. from hp tuners
Old Apr 5, 2016 | 01:30 PM
  #29
Flewbyu123's Avatar
Ok I will try that as soon as I'm off from work..
Old Apr 5, 2016 | 02:50 PM
  #30
Flewbyu123's Avatar
P1504 is not showing up, everything else is available
