4l80 segment swap..
Old Apr 2, 2016 | 11:55 AM
Flewbyu123's Avatar
Default 4l80 segment swap..
Do I have to wait for bill at Hptuners or are you able to do it just cause we have tuner. What I'm asking if file is only coming from hptuners?
Old Apr 2, 2016 | 12:56 PM
tgui's Avatar
The latest hptuners software allows you to segment swap on your own computer. You need to find a donor truck tune that has a 80e to swap from.
Post your hpt file and maybe we can help.
Old Apr 3, 2016 | 05:38 PM
Flewbyu123's Avatar
Ok now getting these codes and also my abs light is now.. what gives
0x10: P0740 - Torque Converter Clutch Solenoid Circuit / Open (Pending)
0x10: P0785 - Shift/Timing Solenoid (SES, Pending, Current)
Old Apr 3, 2016 | 07:38 PM
Flewbyu123's Avatar
RickyWardSQC-4l80e-001.hpt
Originally Posted by tgui
the latest hptuners software allows you to segment swap on your own computer. You need to find a donor truck tune that has a 80e to swap from.
Old Apr 3, 2016 | 08:28 PM
Flewbyu123's Avatar
https://www.performancetrucks.net/fo...1&d=1459733258
getting codes 0740 torque converter clutch solenoid circuit open
0785 shift/timing (SES, Pending, Current)
Is it in the tune or wiring?
File Type: hpt
Old Apr 3, 2016 | 09:32 PM
blackcash's Avatar
Donor file has to be the same OS as well.
Old Apr 3, 2016 | 09:37 PM
Flewbyu123's Avatar
Has to be from a 2003 chevy silverado 5.3 2wd ?
Old Apr 3, 2016 | 10:32 PM
Flewbyu123's Avatar
I've been down over a month with this swap worst up grade so far.....
Old Apr 3, 2016 | 10:39 PM
FFDP's Avatar
OS does not mean same vehicle.
It means both computers have to have a matching OS for the segment swap to work correctly.
Old Apr 3, 2016 | 11:18 PM
lxcoupe's Avatar
When you pull your tune off your PCM in HPT it will give you your OS #, for instance 12579405. Just google "12579405 4l80e" and you'll find a bunch of tunes you can grab the trans tune off of for the segment swap. Other than that and running the VSS wires to the PCM, there are no electronic/ programming. What difficulties are you having specifically? Feel free to pm tgui he is the resident 80e swap expert.
