4L80 it is...
Old Jan 12, 2006 | 06:15 PM
Last Call's Avatar
TOTM: January 2007
Default 4L80 it is...
After blowing my 5th 4L60, it is time to bite the bullet and get a transmission that is not going to fail every 6 months and 3,000 miles. In the last 2 years, I have changed more transmssions than oil.
It will have a shift kit and 2500 stall. A local shop is doing the conversion as they have ran out of answers on why the 65E has been failing.
For those who have done the swap, how bad is ratio in first gear? Is a 2500 stall going to be sufficient to get me going?
Old Jan 12, 2006 | 06:32 PM
Wilde Racing's Avatar
How do I change this text
I think so, (it was for me) but I also swaped a 6.0 about the same time so..........
Old Jan 12, 2006 | 06:53 PM
Mort's Avatar
Cool
The stock stall behind a 6.0 with a 4L80E is 2500 rpm in the 1500HD, 2500LD and the 2500HD. I have stalled mine up to 4.xx psi of boost and might be able to get it higher if I hold it longer. You have to hold it a while to get the boost up there. That may be enough stall for you. Sorry I cannot compare it to anything else because it is all I have used. It is the same stall Grippy has in his 2500HD with the Radix.
Old Jan 12, 2006 | 09:07 PM
that's good information! Thanks. I will order my stall at 3000
Old Jan 12, 2006 | 10:19 PM
quicksilverado's Avatar
You have a ton of torque down low which will help, but you will still notice a difference. Wait until you see how much longer it goes before it shifts into 2nd at wot.
Old Jan 13, 2006 | 06:31 AM
bud8fan's Avatar
Originally Posted by quicksilverado
You have a ton of torque down low which will make a help, but you will still notice a difference. Wait until you see how much longer it goes before it shifts into 2nd at wot.
yea...55-60 mph shift 1-2
Old Jan 13, 2006 | 12:04 PM
Last Call's Avatar
TOTM: January 2007
Wow that sounds great. Is 60 mph at the stock 6000 redline or bumped up redline? Is that with 3.73's or 4.10's?
How about 2nd gear, how fast can you take it up to in 2nd?
Old Jan 13, 2006 | 01:18 PM
56mph in 1st,93mph in 2nd and 138mph in 3rd at 6000rpm with 30" tires and 3.73 gears,I run a 3000 stall on mine.
Old Jan 13, 2006 | 03:05 PM
With 3.42 and 6800 rpm I was shifting at 68 1-2.
Old Jan 16, 2006 | 07:11 PM
Last Call's Avatar
TOTM: January 2007
SO, would you guys recommend a higher stall or shorter first gear?
Blwn99x
Mar 24, 2023 11:14 AM
SloSVO
Nov 22, 2020 07:34 PM
blownss27
Aug 14, 2020 08:27 AM
Texas5.3_1251
Mar 5, 2016 08:10 PM
Benloe
Sep 22, 2015 10:24 PM
