4L75e Going Once, Going Twice...
GoatChs (02-15-2019)
#25
4L60e-4L80e Gear Ratios / RPM / MPH Tables
So I used my daily driver tire data in the table (indicates 275/45R20 is 29.74", tire manufacturer states 29.0"...whatever)...I identified the "combo" in the upper left corner of the calculated data (i.e., 4L80 w/ stock gears & 3.42 rear, etc). First the transmission ratios:
Now the RPM & MPH per gear of each trans:
4L60e (stock internal ratios), 3.42 & 4.10 differentials, 29.75" tires.
4L80e (stock internal ratios), 3.42 & 4.10 differentials, 29.75" tires.
4L80e (2.75/1.57 internal ratios), 3.42 & 4.10 differentials, 29.75" tires.
#26
To Pat's point, the advantage of the aftermarket 4L80 planetary set is more appreciable with the higher (lower numerically) 3.42 gears than the 4.10 gears. There is a calculated 7 mph speed reduction in 1st & 2nd gears with the 3.42 rearends and only a 5 mph reduction with a 4.10 ratio. But at this point, on paper at least, the "value" of the aftermarket planetary set appears to be marginal at best FOR EVERYDAY DRIVING. I'm very curious to see how it feels at the track to see how much RPM drop I have on the 1-2 and 2-3 shifts, although admittedly I won't have the benefit of a before/after comparison.
#27
Edit: Found the retaining clip stuck behind the AC compressor bracket. Is that second cable attached to the TB shaft cam for cruise control?
RoadKill03
06-27-2013 10:17 AM
unredeemed
12-22-2004 06:10 PM
tbyrne
17
04-08-2004 08:31 PM
