4l65e stuck in 2nd gear
Old May 2, 2016 | 12:27 PM
Nulty_23's Avatar
Default 4l65e stuck in 2nd gear
Ok I have a 04 crew Silverado 4wd I just swapped a lq9 and 4l65e into from a 5.3 and 4l60e.
The problem is it won't shift it just stays in 2nd I run it to 4500 rpm let off the throttle and then the tq converter locks but that's it. I have replaced all the solenoids and internal harness from the 4l60e that's was still good when I pulled it. I also brought it to the dealership to get reflashed and still nothing. Even replaced the ignition switch
I did have to swap the prnd switch from the 4l60e onto the 65e. The new motor and trans came from an 04 Yukon Denali
I haven't brought it in to get the motor tuned yet since it's not shifting
You guys have any idea what's I could check next
Old May 2, 2016 | 03:30 PM
Wolftrk99's Avatar
Will it shift manually??
Old May 2, 2016 | 04:45 PM
Nulty_23's Avatar
No I only have 2nd and reverse that's it
Old May 3, 2016 | 06:37 AM
tgui's Avatar
Does the 60e defualt to 2nd like the 80e when no power makes it to the valve body? That was one of my many issues.
OP, the harness and connector look OK and have a 12v reading on the power wire?
Any check engine or codes thrown?
Old Aug 30, 2016 | 12:18 PM
Nulty_23's Avatar
I checked for power into the plug and it was live. Also the only codes that show up are for knock sensor codes but it does not trip the cel light
Old Aug 30, 2016 | 01:50 PM
GMCSIERRA5.3's Avatar
when you swapped out the solenoids and harness did you swap out the pressure manifold switch aswell? faulty pressure manifold switch will have the trans taking off in second gear
Old Aug 31, 2016 | 08:19 AM
tgui's Avatar
What are you using to pull codes? Man, you would thing something would pop up.
Old Aug 31, 2016 | 10:13 AM
if the pressure manifold has a issue it will not set any codes off or check engine
Old Aug 31, 2016 | 10:48 AM
tgui's Avatar
Good point. I've heard that thing is a pretty important part.
Old Aug 31, 2016 | 12:12 PM
Nulty_23's Avatar
Just an orieilys Bosch scanner
Yes I basically gutted all the electronics out of the 60e
About20ninj45
Apr 27, 2016 06:32 PM
Jonblarc7
Mar 20, 2016 10:17 PM
Slow91z
Mar 8, 2016 06:25 AM
jbat35
Feb 29, 2016 10:37 AM
DwDrummer
Feb 19, 2016 09:02 PM
