4L60E separator plate: OEM vs transgo
Old Oct 20, 2011 | 07:22 PM
sintered's Avatar
Default 4L60E separator plate: OEM vs transgo
I've only used the OEM separator plate in my last builds with torlon checkballs. Considering getting the transgo plate this time just to try something different.
Should i order another OEM plate and gasket set from the dealer? Or should I just get the Transgo plate (46-PLT-96 needed here)? What do you builders out there prefer? The truck is a 2005 with the 5.3.
Old Oct 20, 2011 | 07:41 PM
probuilder1's Avatar
I know nothing about building transmissions but when I just installed my converter and shift kit I ordered the transgo plate that way I had it drilled and ready to go in when I pulled the trans out.
Old Oct 20, 2011 | 09:20 PM
jiar577's Avatar
Get the Transgo plate and be done, it's a lot thicker & more durable, worth it.
Old Oct 20, 2011 | 09:43 PM
Vince B's Avatar
If you have a new OEM plate with torlon ***** then you will be just fine. A TG plate is not going to do anything more with using those ***** so I would not waste your money.
SloSVO
Nov 22, 2020 07:34 PM
Wolftrk99
Dec 3, 2015 08:12 PM
bearden86
26
Nov 15, 2015 03:58 PM
Wolftrk99
Oct 2, 2015 08:17 AM
Closer_2001
Sep 24, 2015 09:15 PM
