4L60E separator plate: OEM vs transgo
I've only used the OEM separator plate in my last builds with torlon checkballs. Considering getting the transgo plate this time just to try something different.
Should i order another OEM plate and gasket set from the dealer? Or should I just get the Transgo plate (46-PLT-96 needed here)? What do you builders out there prefer? The truck is a 2005 with the 5.3.
I know nothing about building transmissions but when I just installed my converter and shift kit I ordered the transgo plate that way I had it drilled and ready to go in when I pulled the trans out.
Closer_2001
Sep 24, 2015 09:15 PM
06, 08, 4l60e, advantages, bad, code, complaints, difference, gm, mod, mods, plate, separator, seperator, transgo
