4L60E Help. Pictures inside.
So, I found out my newer magnaflow Y pipe won't let me get off the trans pan without unbolting the Y pipe. In the process of attempting to get off the pan I proceeded to break off the black plastic clip of the part circled in the pic. What is this part called? Also how do I remove it, do i press and twist the spring clip or yank it out? Thanks
So is it called the transmission shift solenoid? Are both of them the same? I am nervous that I damaged the other one trying to wedge the pan off. I think I will just replace them both. Thanks for the help!
Yes that is a shift solenoid and both of them are the same part. Just pull the clip straight out to remove the solenoid. Keep in mind to old the solenoid while removing the clip. The 1-2 shift valve has a spring behind it and it will shoot the parts out of the bore if you don't hold the solenoid. The other solenoid doesn't have a spring behind the 2-3 shift valves so it will not have tension like the 1-2. Just to give you a heads up.
Make sure to run the ac delco or spx filter, I think I saw somewhere that the cheaper parts store brand filters dont flow as well or have a tendency to collapse ...aslo depending on the year of the trans put the tcc code 1870 valve in and the converter will lock up firmer and help everything run cooler.
this is one of my favorite parts
4L60E TCC Repair Valve Fixes Code 1870 | eBay
SlvrSierra4.8
Oct 1, 2015 09:39 PM
kalikid06
Sep 13, 2015 05:48 PM
muncie21
Sep 7, 2015 09:55 PM
SWINGRRRR
Sep 3, 2015 07:49 PM
