4L60e died today
Old May 19, 2005 | 04:15 PM
  #21
cablebandit's Avatar
9 Second Club
you guys in Texas need to call Rock On transmissions in Krum tx.....Dave built mine and has handled 700 rwhp so far. I am gonna beat the **** out of it some more this weekend
Old May 19, 2005 | 04:16 PM
  #22
w41quad4's Avatar
So what are the actual technical differences between the 4L60E & The 4L65E??
Old May 19, 2005 | 04:51 PM
  #23
KySilverado's Avatar
http://www.superchevy-web.com/tech/0311sc_4l65e/
Old May 19, 2005 | 11:08 PM
  #24
w41quad4's Avatar
Thanks....... so what trucks were given the 65?
Old May 20, 2005 | 12:19 AM
  #25
Sleepy53's Avatar
Originally Posted by nightmarechevy
How long did the 4l60e that he built you last? I think it should be strong enough for me, the 80e is gonna cost a little more and I don't think I will really need it.
When you get the new tranny tell us what you ended up. I'm kinda curious on which one you got.
Old May 20, 2005 | 10:01 AM
  #26
nightmarechevy's Avatar
I went with the Jag built 4L60e because I am not making enough power to really worry about upgrading to the 65e. I will let you guys know how if feels when it gets here.
Old May 20, 2005 | 10:03 AM
  #27
Some info on the Jag 4L60e for those of you curious about it:
• Borg/Warner Low Roller Clutch
• New Bushings
• GM Internal Wiring Harness
• GM Solenoids & Switches
• Seals, Gaskets, Filter
• High Performance Output Pump Slide Spring
• Borg/Warner 29 Element Forward Sprag
• Steel .500 Boost valve
• Wide Red Band, Performance Lining
• "Z" Pack- 15 Element 3-4 Clutches High Performance Application
• "Beast" Heavy Duty Shell w/ Bearings & Wide Bushing in Reaction Gear*
• HP Forward & Overrun Clutches
• Borg Warner Low Reverse Clutches
• TransGo HD-2 Shift Kit
• Corvette Servo
• Metal(Aluminum) Accumulator Piston
• TransGo Separator Plate
• Hardened Pump Rings
• Sonnax 4th Gear "Super Hold" Dual Servo
• Wide sun gear bushing
Wolftrk99
Dec 3, 2015 08:12 PM
cheyenne383
Nov 13, 2015 09:24 AM
Wolftrk99
Oct 2, 2015 08:17 AM
trxmxzx
Sep 29, 2015 07:42 AM
slocaddy
Sep 25, 2015 12:42 PM
