4l60e build with $100 core...
Old Sep 5, 2016 | 06:19 PM
  #551
Wolftrk99's Avatar
After the rain weve had this weekend fron the tropical storm that blew through here, everytime i turned the headlights on or tried to signal a left turn the turn indicator would come on steady and just stay on.... Actually been happening internittently for a while, but finally decided to do something about it, and ended up needing a turn signal socket and these aftermarket replacement lenses are JUNK!!!
Contacts in connector corroded... Badly
New socket in and installed
Left signal lens had about half a cup of water in it...
Right lens is dry
Debating on getting a set of euro type led lenses or going back with factory lenses... At some point i want a set of hid headlights and fogs with a set of halo projector lenses...
Back to the steering issue.....
Old Sep 11, 2016 | 11:35 PM
  #552
Wolftrk99's Avatar
Picked up a set of apc lenses for the truck today, and finally got the 4l80, 6l80, and 4l60 along with the two totes full of 6.0 parts out if the bed!!! Which in turn means i had a chace to actually get into the throttle for the first time in i cant remember how long, at one point i had 4 tires and rims in the bed along with the 6l80 for the yukon for almost a year, then i had the transmissions.... Anyway, 1-2 under full throttle unloaded she will try to break traction....
Old Sep 11, 2016 | 11:39 PM
  #553
Wolftrk99's Avatar
Hoping to finally tear down the mad dog later this week or next...
Old Sep 11, 2016 | 11:40 PM
  #554
1FastBrick's Avatar
Custm2500's Rude Friend
In for what you find there!!!
Old Sep 11, 2016 | 11:44 PM
  #555
Wolftrk99's Avatar
Considering its supposed to have been some beast *** level 3 65, we will see!! Converter already wasnt what it was supposed to be, shouldve been a 26-2800 stall, was closer to 16-1800
Old Sep 11, 2016 | 11:56 PM
  #556
1FastBrick's Avatar
1600-1800 would be a stocker...
Old Sep 12, 2016 | 01:06 AM
  #557
Wolftrk99's Avatar
The converter was again as i remember supposed to be 26-2800 and behind the stock 5.3 was actually more like 2200 but for some reason when i put the 6.0 in front of the same converter it got alot tighter and ended up more in the 16-1800 range.... Thinking the converter was on its way out... I remember googling the stamp on the converter and it was some off the wall brand reman tb converter, but the dacco i bought to replace it with was a lot better.... Still have that under my toolbox!!
Figured out this week what my next project will be on the truck.... Fixing the front end and giving my tires a bit more room by modifying the fender a little bit and replacing the inner fender liners... Alomg with finally getting my damn headers and engine mounts installed!!!
Old Oct 6, 2016 | 10:51 PM
  #558
Wolftrk99's Avatar
So am much as i dislike the mechanical side of the 2014 and up trucks i found one that may make me get one.... Realtree edition!!! However until i get some other stuff taken care of that isnt going to happen.... So in the meantime i had the guy that does all the graphics at work make a set similar to the door graphics but in a slightly different realtree pattern...
Old Oct 13, 2016 | 04:34 PM
  #559
Wolftrk99's Avatar
The guy funished up my door decals today and brought them to me, need to trim some of the white border his machine left on them but other wise they look good...now to find time to finally get the truck sanded and get them and the rest of my decals etc on it.....
Old Oct 19, 2016 | 09:34 PM
  #560
Wolftrk99's Avatar
My first instinct is to say something about when it rains it pours, however...... master cylinder went out tonight, at least randomly anyway, had to take my daughter to a thing at her school, and half way to get her the pedal went to the floor out of nowhere, and them felt spongy or would go to the cloor the rest of the way to oick her up and take her to the school, went to leave an hour later or so and thepedal was fine....
