4l60e build with $100 core...
Old Feb 23, 2016 | 10:57 PM
  #331
Wolftrk99's Avatar
All rockers on engine turns over with ease except for the ridiculous compression it is, that or im just that damn tired...... Time to reassemble!!!
Old Feb 24, 2016 | 12:58 AM
  #332
Wolftrk99's Avatar
Bank 1 rockers in....
Coil packs
Timing cover installed
The purple balancer adds 50 hp, if for no ither reason than.... ITS PURPLE!!!!!!! After looking at this pic i wish my block was painted aluminum too!!!
I give up for the night.... Water pump belts radiator flush heater core etc etc etc will be tomorrow....
Old Feb 24, 2016 | 09:17 PM
  #333
Wolftrk99's Avatar
Well shes back together...
Saw no point in boring everyone with water pump on radiator in blah blah blah!!!!
Still not sure whether i wanna tell this story or not, but...... Ill do it anyway....
So being anxious I decided i wanted to fire it up before i got too far with everything but didnt want to run it without the belt on it, so i got belt on, decided it was time to start her up then i thought wel no maf isnt hooked up, so i argued with myself for a minute, and figured speed density for 15-20 seconds just to make sure nothing onvious was wrong was going to hurt anything...... So i fired her up and about the time i think about reaching down to give her a little gas, i hear what sounds like running water.... I shut the truck down real quick run around the front and realize for the second time on an initial startup on this truck i left the trans cooler lines open..... such a dumbass!!!
Old Feb 24, 2016 | 09:35 PM
  #334
Wolftrk99's Avatar
I havent even had a chance to drive her yet, other than out of my buddy's garage.... We are in middle of some ridiculous storms and his sideyard is a mud pit and on just enough of an angle that with the peanut butter crap they call mud around here it took 4wd and goosing it to get it upbthe hill beside the garage and the gate is just wide enough for the truck to fit through any sideways sliding would be very much not good
Old Feb 24, 2016 | 10:20 PM
  #335
1FastBrick's Avatar
Custm2500's Rude Friend
Good deal! Glad to see you finished it.
We all have our moments...
Old Feb 24, 2016 | 10:29 PM
  #336
Wolftrk99's Avatar
Yeah but the same thing twice, in similar situation.... Think this was just a serious overtired excited moment
Old Feb 25, 2016 | 07:03 PM
  #337
Wolftrk99's Avatar
Default Square coils worth the time and energy??
I have recentky acquired a full set of 8 square coils from an 04 lm7 would it be worth my time to swap them in place of the round coils on the 99??
Old Feb 25, 2016 | 08:00 PM
  #338
1FastBrick's Avatar
I don't believe there is any difference performance wise. I was under the impression the round ones with the heat sinks were better since they could dissipate heat.
Old Feb 25, 2016 | 08:43 PM
  #339
Wolftrk99's Avatar
I thought the square ones had the heat sinks, i know the square ones reposition the wire a little higher off the valve cover which tends to help with header routing
Old Feb 26, 2016 | 12:47 AM
  #340
1FastBrick's Avatar
If there a better fit I guess go for it.
Found some info but nothing conclusive to me at least. The truck ignition coil upgrade - LS1TECH
